Lol at RBR putting the woman up to collect the trophy. So much uncomfortable.
"She takes care of the boys"
I am not touching that one.
well they did tell Perez to toughen up...
McLaren don't tell their drivers to bend over - they let them race. And good on 'em!
Mercedes are suffering the same fate as the last couple of years. A strong start to the season then quickly fade away because they have NFI how to make the rear tyres last. The first few tracks must be more 'front tyre limited' which makes Merc look better than they are. If F1 had decent tyres and refuelling, the Merc's could be genuine front runners. They make old-school F1 race car - ones that go fast on low fuel. But they suck at the game of conserving tyres designed to degrade.
RBR seem to love the warmer races that use Mediums and Hards. Malaysia and Bahrain, their pace has been untouchable. They seem to come back to the field in the cooler races that use the Softs and Mediums.
Fastest lap of the race 4.5sec slower than qualifying. Awesome...
I have to say I really like Whitmarsh. I like how he responds directly to questions, how he handles the drivers. I think back to the sphincter of the universe and the example of how to let your drivers race
Perez looks like he had a bit of wind in him, mde for good viewing but he wasn;t showing a lot of race craft considering the pace advantage he had over Button
Lots of good battles and more than anything so glad Romain was in the fight and showed some nice race craft
  • Like 1
Both him And Domenicali seem to have a very earnest quality in interviews.
Other team bosses less so.
he simply lacks the aggression and arseholery needed to make super passes.
getting passed twice with less than 90 seconds to go was a super special effort for the ozzie battler
meanwhile, his team mate with ostensibly the same car finishes 17 minutes ahead of second place
Bahrain Grand Prix organisers are considering holding a night race next year.
With the 2014 grand prix marking 10th anniversary of the inaugural Sakhir Formula 1 event, track chiefs are determined to do something to mark the occasion.
Although nothing has been finalised yet, Bahrain Grand Prix chairman Zayed Al Zayani has revealed that several possibilities are being considered - including a night race.
"We are looking at many options. A night race could be one of them, but it is not the only one," Zayani told AUTOSPORT.
"It is our tenth race, and our tenth anniversary, so we want to do something different.
"But different doesn't necessarily mean we will race at night.
"There are pros and cons to doing it, and all options are open."
AUTOSPORT understands that if plans for a night race are given the green light, then the lighting infrastructure will be made permanent so the facility can utilise it all year around.
Bahrain is also pushing for its event to become the first race of 2014 as well, which would fit in well with the desire of teams and tyre supplier Pirelli to hold at least one test in the Middle East before the start of the campaign.
Zayani said that no decision had been made yet about where Bahrain would slot into next year's schedule, but he said the venue was prepared for a test and the opening round if required.
"We are ready," he said. "We have had a first race before, we have had a third race before, and fourth race before.
"But it is premature to say when we will be. We will know probably between July and September or October.
"We would love to have the teams here for testing as well. But at the end of the day, that is a decision for them, not us."
http://www.autosport.com/news/report.php/id/106989
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
