Daniel Ricciardo is the Toro Rosso driver leading the race to step up to Red Bull next season, according to his team boss Franz Tost.
Earlier this month, Red Bull advisor Helmut Marko gave his support to Ricciardo, saying he is the "better" driver to replace Mark Webber should the 36-year-old leave at the end of this season.
Ricciardo has proven to be Toro Rosso's best driver in the opening stint of this year's Championship, scoring seven points to Jean-Eric Vergne's one.
Added to that, the 23-year-old has also outqualified his team-mate four out of five times while also securing the team's only top-ten grid position of the campaign.
"Well, performance is all that matters and you definitely can see that Daniel with 11 races more under his belt - which is more than half of a season - is probably in a better situation," Tost told the official F1 website.
"Right now he has the upper hand, which we have seen in Barcelona. But that is a snapshot right now. Generally I would say that both would fit into the Red Bull concept."
However, the team boss has mixed feelings about whether either driver is ready for the job.
"At the moment I would answer with a 'yes and no'.
"Both would have to demonstrate an exceptionally good second half of the season, because don't forget we are speaking about the World Champions, so the requirement profile is quite different to being with a team like Toro Rosso.
"But don't get me wrong, both are on a very good path and everything will depend on the next couple of months as to whether one of the two of them - should the need be there - qualify for Red Bull Racing."
http://www.planetf1.com/driver/18227/8715788/Tost-Ricciardo-topping-the-list
more good news!
New twin turbo v6 NSX sounds a bit cooler. Actually having said that, wasnt there a new NSX in the works with electric front drive and mechanical rear drive? What ever happened to that? Lol
coming 2015!
Honda could supply a second or even a third team when they return to Formula One in 2015 as their deal with McLaren is "not exclusive".
http://www.planetf1.com/driver/18227/8717061/-McLaren-Honda-deal-is-not-exclusive-
http://www.autosport.com/news/report.php/id/107462
I was thinking something more tacky, maybe something like a Carla Zampatti Laser.
So we've had the Williams-Renault / Senna revival
Now Martin needs to get Bruno's management on the phone sharpish so we can have the McLaren-Honda / Senna re-up for twenny-fifteen...
you want them to lose that badly?
:rolleyes:
I don't think it will be "crank it up" in the old 80s sense of the turbo cars. I don't know the details, but I suspect boost will be static, leaving ignition and fuel mapping to be tinkered. Pretty much like the cars of today, plus theres that bigger percentage of power delivered by kers.
Dead right but, they won't be throwing fuel out the exhaust just cause fans want it.
The only limit on the new engines is basically fuel. They are only allowed to carry a certain amount of fuel and it means they will have to be pretty conservative with boost and power if they want to make it to the end of the race. Hopefully they will hot them up to serious power then turn them down for economy but at points of the race lean on it for more power and speed...strategies will be interesting
So they are regulated to 15000rpm, and a specific fuel flow rate for 2014.
Whoever makes the most efficient engine that can run the most air for the specific amount of fuel wins. Lots of lean burn work going on I guess.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
