Maybe they should have kept the dodgy Pirelli compounds for this and refuelling ... Exciting race my ass
The tyres haven't changed yet - they're aiming for Canada or British GP. Its just that track doesn't have any real long/high load corners to f**k the tyres in the space of a few laps. And you can drive as slow as you want, just about, without fear of being passed by everyone. I thought all the slow corners might hurt Mercedes rear tyres under power, but that's not their problem apparently.
Anyone who has ever watched Monaco before knows what to expect in terms of the racing. Absolutely no sense complaining about that.
I don't agree Perez was in the wrong in any of those moves - certainly not the one where Kimi ran him into the armco before the corner!
And he was more than fully up alongside Alonso and made the turn-in to the corner no problem whatsover. When someone has you up the inside like that and there's no room to fight it - sorry, you've lost the position. Even if you are Alonso and even if you are in a Ferrari.
Edited by hrd-hr30
Just when you thought that the tyres were the worst thing in F1 along comes a safety car period that just will not end despite Massa's car being cleared ages ago.
they needed to use microscopes and tweezers to collect every sliver of shattered carbon-fibre
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
