Maybe they should have kept the dodgy Pirelli compounds for this and refuelling ... Exciting race my ass
The tyres haven't changed yet - they're aiming for Canada or British GP. Its just that track doesn't have any real long/high load corners to f**k the tyres in the space of a few laps. And you can drive as slow as you want, just about, without fear of being passed by everyone. I thought all the slow corners might hurt Mercedes rear tyres under power, but that's not their problem apparently.
Anyone who has ever watched Monaco before knows what to expect in terms of the racing. Absolutely no sense complaining about that.
I don't agree Perez was in the wrong in any of those moves - certainly not the one where Kimi ran him into the armco before the corner!
And he was more than fully up alongside Alonso and made the turn-in to the corner no problem whatsover. When someone has you up the inside like that and there's no room to fight it - sorry, you've lost the position. Even if you are Alonso and even if you are in a Ferrari.
Edited by hrd-hr30
Just when you thought that the tyres were the worst thing in F1 along comes a safety car period that just will not end despite Massa's car being cleared ages ago.
they needed to use microscopes and tweezers to collect every sliver of shattered carbon-fibre
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
