Jarno Trulli intends suing his former team boss Tony Fernandes after the Caterham owner failed to pay him out.
"I'm going to sue Fernandes, because he owes me a lot of money," the Italian told Autospirit.
"My career in Formula One ended because I agreed to give up my place, because I was assured that the team would fulfill its contractual obligations.
"To date, this has not occurred."
http://www.planetf1.com/driver/18227/8748685/Trulli-set-to-sue-Fernandes
its also run in the most lackadaisical affair you could possibly imagine
you can jump fences, break into just about any high priced grandstand, stand literally next to the track and almost nobody will stop you
not to mention, generally speaking, everybody is so well presented and nice
Kamui Kobayashi is keen to return to F1 next season but if he doesn't has promised to refund all those who sponsored him.
"I want to come back to Formula one next year," crash.net reports him as having said, "and there is one thing I want to be clear about 'Kamui Support'.
"The donations of Kamui Support have not been used at all this year, because this was purely for F1 seat.
"If I don't need to use them for next year's F1 seat, I want to return all to [those] whom made donation."
http://www.planetf1.com/driver/18227/8755336/Kobayashi-chasing-2014-comeback
the whole merc testing row seems like fairly big news
team cheater are also embroiled in the scandal
seems like everybody will walk away fairly unscathed
Which will be a surprise to no one. Team cheater get away with any and everything. Cause cheaters are important to the sport or something. Maybe the FIA shoud have asked them if the rule should be applied? They used to do that in the good old days.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
