yeah, if taking out the leader and 3 other cars from the places they deserved makes a race awesome... Perez's tyre almost took out Alonso as well. That would have been even more awesome.
Vettel and Rosberg (and probably many others we haven't heard about) had tyres with visible damage and almost at the point of failure at one of their stops.
it may have made a spectacle out of the race, but it only hurt the actual racing and had far too big an influence on who finished where.
This headline sums it up nicely: Rosberg lucks in to victory as tyre failures wreak havoc with race
Edited by hrd-hr30
As Dan said pre-race everyone thought that tyre durability was not going to be a concern for the race and it was going to be a pretty straight up fight.
How wrong they all were. It woudl have been a perfectly good race if the tyres had not blown up as Vettel on Hamo would have been a good contest and ditto Webber in the back of the top 10 trying to come back through. The DRS zone made life rather easy so didnt need tyre grenades
Too pissed at Pirelli to even bother reading the follow up news
Ruined Hamiltons home race, stopped Sergio from embarrassing his team mate again, robbed JEV for a chance to show his stuff to RBR along with dan, and gave people the opportunity for spectators to sympathize with that little weasel of a joke in the red car
Cant wait for next week, where its just as high speed as this week
Edited by ctjet
Didnt anyone else see the red turtle shells and banana peels? hamilton managed to score a lightning strike on vettel. Webber stuffed up his start but lucked out and drew the flying bomb... Tyre shenanigans aside it made for an exciting race with shit head not coming first for once..
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
