I am pumped. Dan has been called up to test the RBR at Silverstone. Lets hope he can seal the deal and we see another Aussie in a top seat next year
Joe Saward seems to think its the wrong choice fro RBR and they should be looking at JEV.
Also interesting to see Coughlan has left Wiliams and Pat Symonds has signed up. SO many changes cant be good for Williams but hopefully Symonds can convince Maldanado to bin it and get Bottas in a good spot after a safety car
It should be pointed out that Joe Saward is a pharken idiot who's opinion is not worth a cold dog turd.
Looks the goods, wonder how much cheaper Kimi he would be....
SMACK BANG ON THE MONEY THERE. Our boy is looking real good as the chins replacement. However, will come down to dollar amounts vs experience
I bought the G27 the day that F1 2010 was released for PC, played it about 4hrs that Friday night then put it back in the box never to be touched again. Was planning on selling it but may need to hold out until F1 2013 Classic Edition is released...
And Sainz Jnr was only 0.044s slower than Dan in the STR on his first ever drive in an F1 car. That's faster than Dan was in his first drive of the RBR, with 2yrs F1 experience under his belt...
Edited by hrd-hr30
Track condition, temps etc will have something to do with it. Hard to say how much however. But seen as they were on different days I don't know if it will be quite as bad as it looks on paper.
Must be hard driving 2 different cars in the same day. Wasn't entirely shocked that he was slower in the Red Bull considering it wouldnt be set up for him or even designed with him in mind. So yeah hard to really say, hopefully its not a cross against Dan's name
World Champions stand. Was there this year, up the back this time. Was right in the front row this year which was alright but everyone walked past all the F$&@#$@# time which meant you had to move your legs all the time
Just wonder if the dates are locked in now that Melbourne isn't round 1 anymore. I'd like to look into accom soon but cant really do so till the date is set in stone
Pretty sure no setup changes were allowed on the car on the day. Not sure what they might have changed overnight....
Werent the established drivers forced to run the new tyres with no setup changes...vs the rookies allowed to test development parts and change setups? Many variables for the relative pace....but all the same Sainz was impressive first time out
