The whole F1 circus is a farking joke !!!
10 place grid penalty for that !! fcuk me !
What happened to the days of swilling champers and snorting coke off the boobies of race queen porn.
Anyone else see the "bernie says" shite at the beginning of the broadcast...?
makes me feel even more like this:
Webber & Alonso only got a reprimand. Webber got a 10 spot grid penalty because that was his third reprimand.
When you watch this, I reckon he's lucky that's all he got!
Edited by hrd-hr30
So pottering around at 60km/h is a problem? It wasnt pretty but hardly dangerous! If either Merc had to swerve to avoid then fair enoguh but the fact they took a long arc around the Fezz suggests they saw it with plenty of time.
Webbers other two offences are were I think the Canada yellow flags where I recall Button and others all got done and the clash with Rosberg at I cant reember which GP. From memory it was a BS clash and warning...but seems to have added up to bite him the ass. Three trumped up BS issues have now cost him any chance of a strong Korean GP.
And dont get me started on safety. If you saw the cluster fark cauised by officials in GP2 then you woudl understand why I think this is a bit of a joke
both Mercedes swered to avoid Webber/Alonso parked on the exit of the blind corner. Go to 1:10 (I did the copy at current time thing, but it doesn't seem to have worked here)
http://www.youtube.com/watch?v=UXMCLiAvzg8&feature=player_embedded#t=72
Edited by hrd-hr30
There is two parts to that. A) It is a non event. He unwound some lock to go around Alonso. I dont call that a swerve!
BUT, the second Part B) Was that it did have the potential to be far more dangerous than it was. If Lewis was checking steering wheel...looking in the crowd for a lad boy etc then it coul dhave been comical like the GP2 stuff up
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
