Rules say stay off the track until all cars are off the track in parc ferme. Simple.
Two cars had to dodge the parked Ferrari on the exit of the blind corner.
Webber was running around on the race track in front of one of those cars who had to alter his path to miss both him and the Ferrari.
The other had to go off the track to avoid them.
A reprimand doesn't seem out of order at all.
Well, I will start passing the hat around now to cover the fines Webber is going to be handed at the end of the season when he drops some helis/burnouts in Brazil. It will happen.
I get the rules and what happened. I just find it a bit silly that it is a ten spot penalty for the next GP! And yes I udnerstand its because its his 3rd reprimand. I just went back and looked at the Bahrain clash with Rosberg and its a bit silly that Webebr chopping off Rosbergs nose after he awkwardly placed it up the inside into a disappearing gap and earnt Webber a 10 spot penalty.
Anyway... this is as silly as the fine that Hamo got back at Silverstone a few years ago hecause he dropped a donut or Alonso's fine in Spain the other year when he won!
Also seems the booing of Vettel is here to stay. I would rather it didnt happen but ultimately dont really have a problem with it. Commentators seemingly agree its part his dominance, part his perceived status at RBR but mostly what happened in Malaysia. I guess Karma is a b&$ch!
you would think that there would be mention of Alonso doing 100kph+ with mark there more of a reason to reprimand?
I see no issue with what they did. if they cant dodge an obstacle at 40 - 60 kph how the fark are they expected to when on the noise.
Yeah I was pissed at Webber's penalty until I saw the CCTV footage. That was dumb, stopping just around from a blind corner was dumb. Alonso should have pulled off the track. Webber shouldn't have played frogger with other cars on cooldown lap to get a lift. A reprimand for both drivers is justified IMO.
10 spots is a harsh penalty, Mark seems to cop it from all sides sometimes but it's a consequence of a 3rd reprimand so fair enough. tough luck, son. F1 should be held to the highest standard for all concerned, just because something happened in GP2 doesn't make it OK for F1 to lower its standards. Having said that, some leeway for sportsmanship and showmanship should be given. Schuey used to dance and sing a bit on the podium until some grand poo-bah got their nose out of joint, and drivers used to do a bit of a burnout to celebrate now and then. none of that happens, it's f**king boring yes sir no sir i have a really itchy spot on my forehead by the way did you see the nice big watch i'm flashing in front of the camera (massa is an expert of that move during post-race interviews).
I agree with burnouts at brazil until the tyres pop. it would be so worth it. f**k bernie and his increasingly shitty formula.
I have decided I am going to be one eyed on this! :) Plus, they can say what they want...the fact the FIA have come out this week and said drivers are not allowed to do it anymore tells you the tone of their concerns, irrespective of it being done off in tehy kitty litter or in the middle of the road. Thinking back did Alonso get a fine for collecting the Spanish flag a few years ago after winning in Spain?
I can understand there concerns. I mean hell if he were to fall off he'd be going straight under the rear wheels. The location was a piss poor place to do it and the penalty i think is fair. If they were to fine webber instead that wouldnt solve anything. I mean hell vettell recieved a $1000 fine (was it?) for 9km/h over in the pit lane. He earns that in minuites! How is that due punishment?
Thats like me recieving a speeding fine for $2.50 for 20km/h over out on the street. Shit idd speed around all the time! Ah its only $2.50. I'dd even pay in cash! :D
However that's not to say i didn't enjoy watching it happen!
The sports lost some of its original charm at least from the late 80's to early 90's. That happens of course and there's nothing we can do to change that. However as stated above im all down for f1 ring making on the pit straight! :D
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
