Webber pitted for tyres, next lap Perez tyre exploded & Web got puncture so had to put straight away under safety car. The Sutil lost it after the restart straight into the side of Webber who then caught fire
i have to admit.. them korean girls didnt look half bad.
Hulk is a fkn champ driver, I loved how he just bewildered hamilton for 15 laps
If he doesnt get a good seat next year I will be dissapointed, also wtf happened with di resta.. He was so consistent and in decent postitions all of last year and first half of this year then BAM HAM MODE ENGAGED
Hulk's traction out of those corners was crazy good. To get back past hamo before the drs line and then drive off into the distance with drs open was just plain funny. As was the jeep trundling down the straight.
Rbr's bank account will be taking a battering with 2 cars going up in flames in 2 races. If it happens again I'd like to see Mark pull out some marshmallows and roast them on his car.
prolly would have been a different story if Mercedes had geared the car taller in 7th instead of him bouncing off the limiter with DRS open
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
