Maria De Villota: F1 reserve driver died of 'natural causes' in Spain
"I can confirm that her death was due to natural causes. The family has been informed," Dr Joaquin Lucena Romero, head of forensic services at the Institute for Legal Medicine, said.
http://www.bbc.co.uk/sport/0/formula1/24487701
Good news there I guess..
one for roy.
Heikki Kovalainen says he's ready to return to Formula One after once again showing Caterham what he's got in a Friday practice.
The Finnish driver was in action for the team at the Suzuka circuit on Friday morning and covered 22 laps with a best time of 1:37.595.
His time put him half a second up on race driver Giedo van der Garde.
Kovalainen, though, has yet to learn whether he'll be back on the grid next season and is not willing to speculate about his chances.
"The negotiations are going well," the Finn told the BBC.
"Caterham know what they get from me. They just need to decide what they want to do.
"I feel like I'm up for it and ready to go for next year."
But, he added, "it's difficult to speculate whether or not I have a chance."
http://www.planetf1.com/driver/18227/8967074/Kovalainen-up-for-F1-return
Oh go away already Heikki. Nice guy but poor in a Renault. Poor in a McLaren. And Petrov matched-beat him...now he runs round "I was a McLaren driver and dumped but too good to pay for a drive." He would be lucky to get a seat even if he paid.
I like Caterham and would rather see them throw their weight behind talented youngsters in the hope that a tp team would place them with funding. McLaren?
^Starting from the clean part of the track for once, will hopefully give him the edge. As we as his lower downforce rear wing, to help pass Vettel back if he stuffs it. Missed quali yesterday due to watching Rush. Just watched in now. Come on Aussie Grit.
Does the 7Kegs extra that webs has with the older chassis make much of a difference?
chances are that Seb will have further kers issues in the race since cars cant be touched now? yet his laptime without it is pretty impressive still.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
