Like I said above, the 6768 had no problems making power, we did not push it ... barely touching 18psi for the 500 awkw. Making the power down low is where we need it then winding up the boost to make the top end is the plan !!
500 awkw is enough to play with (to start with)... I've done about 8 laps in the car so far... 5 at Phillip Is with no power steering and maybe 3 around SMP North Circuit with the Holinger with oil pressure warning alerts, which ended up being a case of trimming down the alert threshold at low rpms.
Should be fun once its sorted!! Still got to get used to the sequential but no problems slaming through the gears with the foot flat to the floor down the striaght !! :)
Ok guys, I need help finding a rear wing... Voltex can't make me one in time, the local APR distributor has not got back to me, He said he was getting a few dual pane Nemo style ones in (designed by the man!!) and I asked that I get my name put on one...
Anyone have any suggestions on where I can get one quickly or know someone that has one lying around ??
It needs to be 1695mm + 200mm long (including end plates) !!
Michaels email is [email protected]
http://www.kognitiondesign.com
Or lightning composites are in aus http://www.lightningcomposites.com.au/
As are topstage.
Edited by DCIEVE
Thanks... Freddy seems pretty good. See how I go. I like his front diffuser too.
Need to find someone to make the wing mounts. Thinking of going around the back and under the car ala GT3 style??
New fuel system was fired up today.
New Turbo should be delivered by end of next week.
Will need to wait for Jim (Tunehouse) to get back before it gets tuned. Gives me two weeks to get everything else done.
Still need to choose wing, get it and sort out mounting.
Front bar needs to be remounted and secured better as it broke the side mounting bolts and was dragging on the ground at speed.
Ive been away, back tommorrow... Time to pull the finger out!!
Do you want it in dry carbon or fiberglass John?
I have a custom widebody fenders that will clear 315/xx/18 11-12 inch easily. I have a spare fiberglass front fenders, Topstage has the moulds for both front and rear fenders atm. If you are keen then you should talk to Freddy but I think you are leaving it too late.
The rear will involve cutting your whole fender off and replace it with a dry carbon piece. The front is "almost" bolt on. I made some modification to the firewall for aerodynamic reason and the fender is shaped for it...if you struggle for time and dont have time to modify the firewall, then cut off the inner "flare" of the fender and bolt it straight on to your car..it should still help with the aerodynamic.....that's if you sweet talk Freddy into working 24 hours.
Best bet is to flare the rear and look for another wide front fender. I searched everywhere before and could not find a dry carbon one or even a wet carbon with aerodynamic on it for the r32 gtr...hence I had to design my own. I even bought one from EA and it did not fit. I am happy help you out if you are stuck and let you have my fiberglass one, if you need it, with the right offer..... I really don't know how much it worth...but it costed me a bomb and lots of hours.
Check my build thread if you want some pictures.
Talk to Freddy John. Between Freddy and I, we have most of the R32 GTR body moulds. I don't really know how much to charge you for using the mould...just ask Freddy for a fair price....happy to help another SAU member.
Good luck John and it will be good to catch up on the day.
Thanks for the offer on the front guards just pm me what you want for the fibreglass front guards and send me some current pics of what they currently look like... I will let you know if I am interested.
I was hoping for a bolt up straight fit solution to the front guards and Im anticipating the rear is not going to be that straight forward.
Im not looking for a long term solution as the car will be going on a diet after WTAC and Im going to have a proper look at the aero.
My priority is to get the mechanical, electrical and chassis sorted and get some seat time... Everything has to work and be reliable hence the looks are not so important for my first WTAC...
The FG were prepared and primed for the mould. They have been wrapped straight after moulding and in storage since. I won't have time to take it out just to take pictures but it should look like this
These look awesome! How much wider are they, and are these actual pics of the guards to fit R32 GTR?
Do they have more clearance for extra lowered cars as in John's car now has the option to go lower as the roll centres are raised?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
