Im about to install some tomei type b cams into my r34.
So ive done heaps of searches and it has returned multiple answers...
Does anyone know for certain the valve clearances to follow?
Ive got tomei's specs, nissan workshop specs, under my bonnet the sticker has different specs.
Just looking for some reassurance with which ones to follow, and the searching is doing my head in.
Cheers
What are the TOMEI specs for those cams out of curiosity?
I've heard they are quite large.
People have thrown shims with those cams and i'll bet its because of incorrect shim clearance.
Nissan workshop manual states it is 0.31 +/- 0.04mm on the inlet and 0.5mm +/- 0.04mm on the exhaust.
If I remember correctly (I recently installed the same cams), Tomei says the correct clearance is 0.4mm (intake and exhaust). Seemed quite large, but who was I to argue with the manufacturer :P So thats what I set mine to. I also installed stronger valve springs.
Yeah i put stronger valve springs in mine as well. But i'm only using stock cams for the time being.
Did you set your shim clearance with new shims, or did you rebuild the head and grind the valves down?
I'm not actually sure, I had the whole head rebuilt / reconditioned by someone and they set the clearances.
Valve regrind, then get your machinist to trim the valves to get the right clearance. If you get stuck and need some, Precision Shims Australia have them
From memory we set them up at 0.016" intake and 0.014" exhaust.
That's about 0.4mm intake and 0.35mm exhaust. If you set them anywhere near 0.018"-0.020" it will be noisy as hell
Mine were re-shimmed to Tomei spec 0.45mm in/ex and there is a bit of noise coming from them. Maybe noisy as hell is a matter of opinion but I would run tighter clearances in future.
Ahh yes it was 0.45mm... Which is what I set mine too. Hope mine are not too noisy when I get it going :(
I have stage 2 Tomei poncams I'll dig up the receipts and find out what mine are can't remember lol but my head and everything was rebuilt when cams were put in. Oh I'm tuning r34 gtt neo you will love how it sounds when you got em in I know that much
Edited by Cyifly
hahaha once again I have been given several different answers.
Thank u all for the advice though.
Any more experiences?
The size tolerance you used and if it was noisy or not?
Thanks again
Do you mean noisy exhaust wise? Or as in engine cause mine is noisy exhaust wise.
Engine does make a lil bit of noise can really hear when the cams are ticking over. Hope tht answers your noise question
My poncams as per receipt:
260 degrees 9.15mm intake
260 degrees 9.15mm exhaust
Off engineering receipt:
Was machined 20 thou over by memory
List:
Modify pistons to neo spec
Repair can tunnels
Supply retainers and locks
Machine crank and fit sleeve
Supply and fit valve guides
Hot tank engine
Port head to race
Supply valve springs
Fit oversize inserts
Supply inlet and exhaust valves
Bore and hone block
Modify oiling
Supply rb25 crank shaft
Drill and tap oil gallery's
Manufacture seats
Deck block
Manufacture vernier gear
Assemble Aline pistons
Engine balance race bearings
Arp head studs
Seals
N1 oil pump
Welsh plugs
Not sure if that will help at all man but yea.
Was all done at Jhh engineering in Woodbridge Queensland.
Perhaps give em a call cause rb25 rebuilds are what they specialize in race spec.
0732086274
If anyone will have The answers they will just can't remember that far back.
Edited by Cyifly
Hey all just an up date.
I checked the clearances and all good, used Nissan spec and they were all within.
The valves are making a decent tick though. Not horribly loud, just enough to be annoying.
Made just over 300 with no loss in response.
So prettyhappy
Thanks all for your responses.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
