Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
  • Replies 76
yeah as the 4 events we currently run a year make it sooo hard for you..
if something happens that far out it will be a nightmare/chunk out of the pocket to get back
I've been going to these for 6ish years, can count on one hand the number of times some-one has had to get a tow truck.
more likly to bin it on the GOR than at deca..
exactly.... also of all the times someone has been towed.... most of them were grant
buuuuuuuuuuuuuuuuuuuuuuuuuuuuurn
yes but he got towed from GOR as well, so my comment still stands.
Was hoping fatherhood will make you all warm and cuddly, obviously not...
If you can afford a 34R, surely a tow bill (or few) won't be much of a trouble for you.
^^ everytime you post I think your username is dick cleaner
LOL yeah your sub conscience mind is definitely at work here. Its actually not a bad name to give a broad minded person haha
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
