Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
  • Replies 76
yeah as the 4 events we currently run a year make it sooo hard for you..
if something happens that far out it will be a nightmare/chunk out of the pocket to get back
I've been going to these for 6ish years, can count on one hand the number of times some-one has had to get a tow truck.
more likly to bin it on the GOR than at deca..
exactly.... also of all the times someone has been towed.... most of them were grant
buuuuuuuuuuuuuuuuuuuuuuuuuuuuurn
yes but he got towed from GOR as well, so my comment still stands.
Was hoping fatherhood will make you all warm and cuddly, obviously not...
If you can afford a 34R, surely a tow bill (or few) won't be much of a trouble for you.
^^ everytime you post I think your username is dick cleaner
LOL yeah your sub conscience mind is definitely at work here. Its actually not a bad name to give a broad minded person haha
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
