Hi all.
As you may know, Andrew at AM Performance (a SAUSA sponsor) has been working on an intake for the M35 for the last couple of weeks, using my car as the dummy car.
The intake, which is about v2 or v3, is now complete and on the car.
It's an interesting design, whereby it steps off the turbo at 2.5" (same as the turbo outlet), and expands to 3". It's been made in two halves, with the halves held together by a spring. It's a design Andrew has been using for some time on other cars with great success, and is easier to use than a piece of silicon and hose clamps.
The shape is designed for both maximum flow and to ensure that it fits around things on the car, primarily the air con hose, without stretching it and causing stress on it. After all, these things are our road cars and we want creature comforts!
Here it is:
post-34363-0-20761100-1354269710_thumb.jpgpost-34363-0-70174000-1354269734_thumb.jpgpost-34363-0-78629300-1354269743_thumb.jpgpost-34363-0-15409400-1354269753_thumb.jpg
Here it is on the car:
post-34363-0-05920600-1354269809_thumb.jpgpost-34363-0-37838400-1354269871_thumb.jpgpost-34363-0-28789900-1354269939_thumb.jpgpost-34363-0-96831700-1354269982_thumb.jpg
On my car, I've chosen to use it with a pod, a R2C pod to be specific:
post-34363-0-00538100-1354269998_thumb.jpgpost-34363-0-70506900-1354270018_thumb.jpgpost-34363-0-45616500-1354270026_thumb.jpg
The same intake can be used with an airbox. You just need a slightly longer piece of silicon (90mm from memory):
Andrew has jigged these up and will have them for sale soon on his web site, www.amperformance.com.au. Looks like retail will be $480, but if people are interested I will organise a group buy rate.
Let me know if you have any feedback and if necessary we can incorporate into another version in the future. If you're interested in a potential group buy let me know and I'll get something organised.
https://www.sau.com.au/forums/topic/414739-m35-am-performance-intake/
  • Replies 42
Hi all.
Here it is:
hey Ryan looks the goods, any physical gains in the change over . Cheers rudi
Not sure yet Rudi. I have to fix my overheating problems before I can properly measure. Hopefully that will happen today and I can thrash it tomorrow on the SAUSA cruise. Do you have an ECU you can tune yet?
He should advertise these on yahoo Japan!
Good idea. He sells a lot of his stuff overseas now, so it will go up on his web site and hopefully the Russians are interested.
Not sure yet Rudi. I have to fix my overheating problems before I can properly measure. Hopefully that will happen today and I can thrash it tomorrow on the SAUSA cruise. Do you have an ECU you can tune yet? Not yet Ryan:(
Now that the car is back together and the intake is all sealed (needed to replace the hose clamp on the BOV return), the butt dyno says it's better, particularly in the top end. Feels very strong.
I will try and get an after figure on the dyno before my tune, but in the meantime I've had some queries about a group buy so I'll confirm pricing with Andrew and let you know.
Hey Ryan, I dont have tuneable ecu is this needed with the new intake?
No Rudi, you'll be fine. But I think it's best to look at getting one to get the most out of it.
You sure about that? All the cars I fitted one of mine to hit airflow cut from maxed injectors.
+1, mine also maxes injectors, but mine doesn't max the AFM like your 3" bad boy.
Due to the 2.5" bottom section; AM's probably doesn't max the AFM either.
The ones that are maxing out the AFM, is that stock turbo or high flow?
Mine is close but just not quite there. Need to double check injectors but they're also close.
im interested in this but with my minor mods I'm guessing id be maxing out my injectors and AFM too.. i would like to tune mine but ive been quoted an astronomical amount to get it tuned on haltech.. what do you guys use to keep an eye on the injectors and/or AFM ?
Be careful mate, you're getting close to blown engine territory... Get it tuned soon...
Yeah you're right Scotty. Double checked my figures today, and the injectors are maxing out. The FPR will get me out of the shit short term but I'll be getting it tuned shortly. You get the email from the HKS guys about the tune?
Chris, give up on the Haltech. As far as I can tell, Craig had it running... badly... and it was pretty expensive. Go with the proven options; Greddy eManage or HKS F-con.
Greedy informeter is a cheap option to get the data.
Yep, that's what I'm using Ross. Great for comparing data and working out what you're doing to the car. And saving your engine if you're doing stupid shit with intakes ;)
So, after spending yesterday and today driving the car, and especially today being able to check the data on the informeter while woman drove me home from a beer tasting, I've been able to confirm the injectors are maxing out, but the AFM is not. I have a theory on the AFM, which is basically that you won't get much/any higher voltage on the AFM without going highflow turbo with 3" centre, to match to a 3" flange on the intake. I'm at 4.85V now, and I can't see it getting any higher with the stock turbo.
Car feels very strong now, and fuel economy is better. AFRs are different without being dangerous.
Given the injector situation I wouldn't recommend this to someone who doesn't have some way of tuning the fuel. This could be something as complex as an emanage or F-con, or something more basic like Leon's voltage manipulators. I'm going to use an adjustable FPR for now to give me a little more headroom, and some safety, until the F-con is tuned.
Short of installing the two sensors the car, it's now ready for the tune. I have three to pick from now, have spoken to two of them and will speak to the last one tomorrow, who has apparently worked with F-cons before. Hopefully it can be tuned before Christmas on 98, no E85 for now. I want it in and working before we stuff around with E85 as I'll want to run either multiple maps or flex fuel.
Good idea Chris. I think you have a HKS approved tuner over in WA? Might be able to find the name on here if you search, but not sure if they're affordable. If not I have someone else I can point you to.
Informeter's are relatively cheap on ebay. Excellent insurance!
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
