Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
(Prices Negotiable)
R32 Indicators $40pair lenses great condition, plastic clips are broken
R32 Side Mirrors Black, R/h has slight damage as seen in pic, LH is undamaged $60pair
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $300
Also have a std R32 Gtst drivers seat laying around in good condition for $40,
Dash Cluster R32 GTR (Will fit any R32) Immaculate condition with only just over 150000kms on it. $50
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $150, Button $30 post-44496-0-95102800-1354439884_thumb.jpgpost-44496-0-94130200-1354439892_thumb.jpg
R32 GTR genuine Front Grill Very good condition $150
HKS intake kit for GTR with 3A racing pods only used for 2000km $200
Autometer Tacho with shift light $20 perfect working cond, with all brackets wiring req.
Pwr FC hand controller $300 late model pwr fc
Intercooler 600x300x100 $200 3" inlet/outlet big hks style tube and fin used for 2000kms $180
3" cooler piping from twin turbo pipe to plenum $180 incl hose clamps and silicone joiners
Trust Type R BOV $300 stiff spring type used for 2000kms
R32 rear bar great condition $100
R32 Mspec side skirts very good condition $100
R32 GTR Gearbox great condition low kms, shifts very well and has redline synthetic oil in it $500
polished dished Work Equips 18"x10+28 fronts, 18"x11.5+24 rears $2200 (tyres very poor)
post-44496-0-11981500-1354438815_thumb.jpgpost-44496-0-12466200-1354438830_thumb.jpgpost-44496-0-65374500-1354438835_thumb.jpgpost-44496-0-78718400-1354438841_thumb.jpg
HKS Super dragger 3.5" exhaust cat back to suit R32 chassis and twin front pipe to suit rb26dett will separate or $500ono the lot excellent condition polished cannon 5"
a pair of 25mm bolt on spacers to suit skyline etc 5x114.3 $100
R32 drivers door control switch board perfect condition $60
RB26dett a/c compressor good condition $60
Rear adjustable camber arms to suit R32,S13 etc $80
R32 GTR front and Rear driveshafts perfect condition $100ea also have transfer shaft from gearbox to front diff and tailshaft
ARC R32 GTR castor arms will also fit GTS4 great condition will all bolts $140
Rb26 starter motor $100
HKS 2530's $2000 pair turbos only, done 2000kms have oil drains, lines, std dump and manifolds etc enquire for price
post-44496-0-29139600-1354439251_thumb.jpgpost-44496-0-88160400-1354439268_thumb.jpgpost-44496-0-00615300-1354439288_thumb.jpgpost-44496-0-46621000-1354439293_thumb.jpgpost-44496-0-82637500-1354439300_thumb.jpg
Polished twin turbo pipe both pieces and hose joiner $200
Splitfire coilpacks used 10000kms to suit RB $450
Tein Coilovers to suit R32 GTR and GTS4 $800 very good condition no leaks, heavy spring rates of I think 12kg and 10 kg height adjustable go very low, and damper adjustable have spanners to suit also
R32 Japanese Fibreglass front vented guards good condition $300 with mesh in vents (not cheap local made are durable guards)
Forged RB26 for more details see my other posts
Stripping whole car so if theres anything your chasing just let me know the bolt on flares as pictured are also for sale come with polished head bolts $200post-44496-0-18758900-1354439917_thumb.png
Names Johnny I would rather you call or txt, otherwise please PM, avoid posting on the topic thanks
0414596256
still have hand controller, wheels, exhaust, seats, mirrors, indicators, steering wheel and button, ac compressor, drivers window switch, front guards, spitfires, engine, gearbox, tacho, boot no wing holes professionally filled with genuine lip, steering rack, r32 front brakes hubs and rotors, dash, aftermarket front strut brace, plenty of rubber and plastics in VGC ask away anything you are looking for
  • 2 months later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
