hey guys, was driving the stag yesterday and the motor just died so i pulled over and attempted to start the car again but no love. I know its not the battery as all lights are on and car just wont crank over. Could the coils have lost their spark or it couldnt happen to all of them all at once? If its the crank angle sensor what symptoms are shown?
Car is a c34 auto with nistune, ss2 turbo and other basic mods. Engine light was showing but always comes on when its hot or at night but speedo also dies after a while its left in drive. When that happens i chuck it in tip tronic and the light disappears and speedo comes back on.
What other gremlins may have caused this?
https://www.sau.com.au/forums/topic/414856-stagea-wont-turn-over/
What do you mean by "won't crank over"? Nothing happens when you turn the key? Can you hear the solenoid click when you turn the key? Check the battery terminals for tightness and cleanlines. Check the earth strap. Check the lead down to the starter motor. Use a test light to check the main fuses in the engine bay. Ignition switches sometimes pack up. Won't be the coils or CAS if the engine won't even turn over.
Yeah ur battery may have a dead or dry cell, this will cause it to have enough power to run ur lights stereo wipers ect but not enough to start it! I had a simmilar problem recently with my wifes 2010 fiesta, took the battery to battery world had it tested, bought a new one put it in and problem solved
+1 for battery connections.
I had a similar issue. Drive to the shops, all good. Came out and went to start the car, nothing. Had all dash lights, stereo, wipers, the works but could only get a click from the engine. After doing some impressive carpark machanics and removing the starter motor to check it wasn't seized or something stupid then fitting it again managed to get it started by short starting it with a jumper lead. Straight to an auto elec who proceeded to do the the most basic thing, check the simple shit first!! Turned out it was I dodgy connection where the terminal clamps onto the cable.
Check the battery connections or try a new battery.
lol, we tried a new battery and same thing still wouldnt start. Now we are looking for a auto electrician to look over the car but as soon as people hear that its a stagea nobody wants a piece of it. Anyone know of a mobile auto electrician based in sydney that knows a thing about stageas?
Ok let's get this clear, does the engine wind over & not start or won't wind over ?????
If it won't wind over can u crank it over by hand? It may have a broken timing belt n bent valves
Edited by GTR260
The biggest issue is - Is this now a new problem ontop of check engine light and speedo dropping off, or somehow a part of it.
When did the CEL and speedo issue start to occur ? After fixing something/replacing something ? Nistune ?
And with no disrespect, lets be very clear on what happens when you start.
Red lights on ACC - YES/NO
Fuel Pump prime on IGN - YES/NO
Starter motor click when starting - YES/NO
Engine rotates when starting - YES/NO
When starting it's misfiring/spluttering and won't run - YES/NO
Diesel was substituted for Petrol - YES/NO
engine winds over but will not start.
Lol diesel. Actually the engine light problem came on 5 hours after i bought the car which is over 2 years ago and comes and goes here and there. When i did get the nistune toshi told me i had a faulty speedo sensor and my 02 sensor was basically dead. Apart from that the car has never given me any issues.
oh and yes red lights on acc fuel pump primes on ign, starter motor clicks when trying to start
ok, so the engine does rotate when starting, but doesn't fire up.
Do a basic spark test
Remove #1 coil pack from engine and connect to a spark plug (leave coil pack wires connected).
Rest the spark plug on an earthed part of car (engine). Attempt to start the car and have a friend look at spark plug for spark. User camera if no friend to be found.
The link below will have pics/info on what to remove to get to spark plugs in case you didn't already know ! Pics are further down in a jumbled order.
http://www.skylinesaustralia.com/forums/topic/42819-rb25det-changing-the-spark-plugs/
^^ starter clicks?? Thats a current delivery issue. At a first guess with a problem like this....
AFM? They have been known to shut you down if theres a bad connection. If you dose it you can stall / break it.
My advice is buy a multimeter and get some data.
Nothing yet, had 5 different auto electricians come to my mechanic and none of them know, dont wanna know since its an import. Been to busy at work to chase this up christmas rush is killing us. Only update now is engine light wont turn on fuel tank doesnt prime so no spark at all. Gonna do a search now for stagea electric info and english version for the fuse box.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
