got pulled over today got defected for fmic,height,rear tyres, copper said that i need to go to a blue slip station to get them cleared after i fix,my main concern is the fmic.can the blue slip inspector clear the fmic or do i need engineers certificate..cheers
https://www.sau.com.au/forums/topic/414882-defects/
Cutting a hole and mounting does require an engin cert. Cops have tried to defect my GTR that came stock with FMIC... It really does suck. The cops in ACT currently have a hate where you "can't have an FMIC and a BOV" it's one or the other. I mean seriously what the hell? i mean im ALL for safety in cars. But some times its a bit silly me thinks.
In saying that goodluck with getting it all sorted!
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6671136
ok.got my blue slip ,,all good.had to get a muffler just before the diff to replace the hotdog ,new tyres,horn fix,he said he was happy with the intercooler how it was installed,and that was it,oh and wind up the rear coilovers,take blue slip to rta and and cleared.....
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6677778
Intercooler + a hole cut in the inner guard is perfectly legal WITHOUT an engineers certificate.
You lot need to learn your standards of what is owner certifiable and be able to politely inform the police of such items and you will avoid defects.
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6680866
the risk with informing politely is if you find someone that happens to know the slightest bit more they will go to town on you for trying to be smarter!
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6681175
If they're booking you for owner certifiable, they don't know their shit.
If that does upset them that you've informed them it's owner certifiable and they do go to town on you for things that you actually have modified illegally, then that's your problem for actually having illegal mods.
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6681396
List of things that do NOT require certification: This list was generated from a Q&A held at Eastern Creek by the RTA, at a Motoring Enthusiasts Conference on 26/02/2012. See full PDF below.
Source: https://sites.google...th-stakeholders
PDF from RTA: http://www.rta.nsw.g...rn-creek-qa.pdf
Sorry, didn't copy and paste how I thought it would, so the list is the first link above.
Proper legal stuff. Its like the PDS/FSG of cars. Boring as batshit, but covers their ass completely.
http://www.legislation.nsw.gov.au/viewtop/inforce/subordleg+522+2007+cd+0+N/?dq=Regulations%20under%20Road%20Transport%20(Vehicle%20Registration
Edited by XS80ST
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6689313
I am a crim/traffic lawyer in Sydney and I am keen to embark on a test case with respect to police issued defect notices.
If anyone in Sydney has recently been issued with a defect notice from NSW Police and has
Not been to have the defect cleared, please PM me.
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6696023
http://www.legislati...%20Registration
Hmm I read your link(https://sites.google.com/site/no2vsccs/3-permitted-modifications/modified-cars/modifications-reviewed-with-stakeholders) and this seems to show modifications which do need certification. If this is the case, there is no listing there about a pod or fmic. It does say if you fit a turbo charger which increases power output by 20% of the original stated, but it leaves out alot of obvious things. It doesn't say anything about engine management, I always thought this was a big point.
https://www.sau.com.au/forums/topic/414882-defects/#findComment-6696049
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
