Hey everyone Im currently stripping my R32 gtst skyline and also another I brought as a write off.. Basically all parts are for sale bar the running gear and the shells. If you have anything you may want please Pm me or comment and I'll get back to you ASAP with a price and if I have it. I'll do up a list this weekend also =]
Thanks Kate =D
Not seliing my front bar.
https://www.sau.com.au/forums/topic/415104-stripping-2xr32s-plenty-of-parts/
  • Replies 120
Posted Images
Depends on who the person is closer to my partner is at Gold coast and Im at Kilcoy QLD.. Can post at buyers expense..
I have 2 surrounds 1 mint black one no scratches no breaks etc $120-
1 thats been painted white with a light surface crack but not all the way through $60-
comes with ass tray and cig lighter if needed.
I'll pm anyone who wants a number :yes:
what more would you like to know? Im doing a list soon but its all interior and panels for sale.. My current reged daily has a 2jz in it.. so none of the running gear is included nor my GTR front bar`and my after market suspension. Ive mentioned my location up the top. I wont include numbers unless pm'd and asked for it.
Kate..
Both cars are basically stock.
Edited by 05lde
R32 mirrors $70 each
2xaircon climate control $80 each
N1 GTR headlights $300 a pair
2xbonnet $90each
L-R front guards $150 each
front calipers and rotors $200
knuckles + hub Front $100 a pair
Front LCAs $120 a pair
R32 cross member $50
R32 steering rack $60
high pressure steering hose $50
front r32 reo $120
r32 brake master with booster $120
r32 clutch master cylinder $30
brake and clutch pedal $150
manuel rb20 tail shaft $100
dash $450
door cards $50 each
washer bottle $60
rear window $500
drive side window switch $100
window reg switch sensor box $50
window reg $100 each
door glass $100 each
door shell $100 each
boot no wing $100
GTR wing $80
stock diff $150
steering colum surround $50
rear hubs + rotors + calipers $250
fuel tank $150
hand brake cable and hand brake $90
tail lights $60 each
rear reo $100
Im sure ive left a few parts out so just pm me if your looking for something else
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
