Me and V8cat have already ordered and received them but the discount wasn't that significant (100 GBP) considering how much you end up spending with shipping and taxes.
But the brakes do look amazing and should be fitting them on shortly once I get my PMU club racers.
If you received 100 GBP from discounted price, it means 1400 GBP discount from retail price.
I went ahead with the order because even after postage, taxes and discounts it was still a lot cheaper than sourcing them locally. All depends on exchange rate as well.
Hey mate if possible could PM what you payed in total for the kit
Thanks
A word of warning, those standard issue pads are not very good when pushing the car hard at all. I took my thing up Springwood road, out near Richmond in NSW (basiclaly a 4 km sprint up a hill. 1st and second gear, I may have snatched 3rd once) and you could feel the pads not liking it. Got a tad spongy.
Yeah, I found that too, I still haven't fitted my PMU Club Racers yet.....They should make the car stop on a dime!
I've heard good things about the Pagid pads. Black and yellows or something.
Anyone know if Endless make a pad in their CC-RG compound that will fit. I had those on standard brembo setup and they were nothing short of awesome!
Alcon kits are road legal in UK so they come with ferodo ds performance pads. They are ok for street use but not for track. I found same information in manual included in box with brakes. Yellow pagid RS29 are the best option for alcons imo. They work from cold, don't squeak, and are very "friendly" for discs. RS19 are not available for alcon 6 / 4 pistons. I checked with jdl last month.
RS29 is the "yellow" Pagid Paul that people speak of... Pagid make two "yellow" and the RS-19 is the lower spec of the two :)
Yeah, Jack said he was running these when he used this kit. He was happy with them.
Hence why I'm not even bothering with the DS performance pads and was recommended either club racers or Pagid Rs29.
Have a read, explains some common brand pads for either street or track.
http://motorsportbrakes.com.au/wp-content/uploads/2013/04/3-Pads.pdf
I never ran out of brakes with DS2500 on the street with a 356mm rotor.
Even on a 15min hills run... And I'm not one to take it easy
ahhhh....that only say's your no good at braking!
Grow some hairy ones me thinks!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
