Hey Roy yeah i didnt even think to mention what pads they were front and rear lol. It is squirmy when cold under hard braking and improves slightly when hot under hard braking only. ie on the limit of abs kicking in. The squirm is very manageable and doesnt feel like its going to come out on me like Ash mentioned. At one of the drive days I had an instructor with me in the car and he thinks there is too much rear braking causing it.
Odds are the DS2500s work from cold and the PMUs need to be over 300deg C before they are in their operating range.
So the DS2500s are offering a higher co-efficient of friction from cold when the fronts are still thinking about getting up to temp. If you still have the DS2500s that the car came with slap them back in and see of the problem goes away. If it does than thats the issue.
Has anyone ran a Pagid RS4-2 with their Alcons. On paper they are a tad better than DS2500s....they are the next pad I am trying
  • Like 1
Loved them personally - good compromise for a car that still gets street driven.
Once they are around 30-25% left they tend to break up if you hit the track or push them hard on a hills run etc so just be mindful of that, but then they are a lot cheaper than other options that don't.
Decided to bite the bullet and order a set of 356mm D2's from import monster next week as my factory rotors and pads are due for a change.
Does anyone know what the pads that come with them are like on the track? Should I bother getting some decent pads straight up?
The street pad they come with isn't bad for street and what they are in a standard kit form type thing.
But having then changed mine to DS2500, you can certainly notice a difference/improvement in all areas... So if you are just circuit then yeah, change them. If just street duties leave them as is...
Or... get a set of DS3000 or another track only oriented type pad and swap the D2 pad back in afterwards for daily driving (some people do that too)
  • Like 1
Are there any issues running 2 different pads on the same rotor? Like issues with bedding them in etc?
I dont have big brakes yet as i am a sook but just for interests sake?
Recently found out that new Project Mu pads don't like an old rotors (that has another brand pad material on them), makes them hard to bed.
Otherwise have not heard of that before then and it was only that brand. I know people who's swapped DS3000s in for a track day and back to a shitty pad for street and it was ok so could be select situations
As always the answer is it depends. You are odds on going to have all sorts of problems if you are going from a semi metallic pad to a ceramic style pad.
From there you can also have problems when simply changing pad compounds. Best bet is that when you go from your street pad to a race pad make sure you do a weeks worth of kms on the race pad in light duty drives. The cold pad will generally not get up to temp and be rather abrasive. Give the rotors a good wipe down with some brake cleaner and then on the way to the track (or night before) follow your usual bed in procedure.
Like wise when switching back leave the race pad in for some street driving to wip pad deposits off using the high friction-cold pad then swap over to your street pad and bed them.
It worked ok for me when I was running Hawks vs RB74s. But frankly that was back when I ran 280mm std brakes and I think with any half decent brake setup then you can quite easily get a pad that serves both purposes these days
You can...but when you are targetting a runout figure lower than .15mm...many say lower then that in performance applications with large rotors then I think most people frown upon rubbing an abrasive on a rotor face in an uncontrolled manner. Also be careful of the grit you use as you dont want to "polish" or improve any surface face that will encourage glazing
  • 4 weeks later...
I heard that is possibility to get 370 mm rotors for Alcon Advantage Extreme. I run with 365 mm kit front and 350 rear, same as here http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html but will need to change rotors soon, and I was thinking about bigger rotors with hats. Can anyone confirm this ?
Stop being weak and go the big boys. My Alcons look the same to the eye as the Advantage Extreme that you are running but they take a bigger rotor in 380 x 35.5. That is about the smallest diameter you should run and they take up to 410mm! But the real benefit is the extra 3-4mm in width and vane size. IF braking is borderline than you have a rather epicly powerful and probably heavy car and 5mm rotor diam will make stuff all difference. Not unless that diam increase also means a change from 48 vane rotorss to 72 vane for instance
I bought R32 GTR, and I plan to buy and install Alcon brakes on this car. Question : does anyone here, plan to order Alcon soon ? I think JDL would be keen to offer little better price for two buyers.
I took two kits off him when I got mine. He didn't give me anything off, however, it's worth a try.
They can give little discount, because I've already bought of them something for my R33, with other forum member, and we received additional £100 off.
Edited by V8cat
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
