Got some thanks to Victory (aka Charles) from the gong.
Charles delivered them this morn and we had a good chat :thumbsup:
talk about a clean 33 4 door - was a top example :D
looking for a set of stock 34 rims.
(cheap but good)
Mmmm... sounds nummy.
So you're putting these Stockers on the R34 and selling?
You should let me borrow the Volks indefinately... :D
Also... someone buy my For Sale stuffs so I can get SkyWagon Sweet and pay for AirFares.
Hi Richard
I have only just put 350Z rims on the R33 sedan and have not had a chance to take any pictures of it. They are 18 x 8 with a 30 offset so they are both legal and fill the guards well.
Here is a picture of another SAU member's car from Qld who I got the idea from for the 350Z wheels.
