Feelin the love in here.
Bought some new nuts (since my missus keeps my current set in her hand bag) to match my soon to be teal brake calipers.
Nice man, my missus is f*cking crazy for teal coloured stuff.
Nice nuts Mat.
Sean, we give to strife because we can.
I get the car on ramps, take off cover, move tray under sump, remove plug, try to catch plug, remove filter and go have a smoke. That usually does it. :)
That's what i did for the oil, but when i went to do the filter i didn't have enough energy to take the sump cover off and get the clamps around the oil filter because it's very tight then i couldn't find the friggin things then i just gave up and wanted to go to sleep.
That's not too bad since it would be much much easier to get the sump cover off. The stock one is such a bitch. You'd think it'd be noisy though wouldn't you? with rocks and shit flying up and hitting it.
On dirt roads maybe - i don't think you'd notice to be honest. mount it with rubber grommets in between to insulate it from the k-frame and you shouldn't get any vibrations or anything.
Sorry they don't make them for boats.
Couple of things:
1- Your car is the same only with less doors, so how many knots does yours so and do you have it tied up at the jetty or marina?
2- ill happily meet you in the bends then say that.
3- the underbody protection plates rareJDM make one that fits sedan and coupe.
I replaced my engine oil last night, so difficult when my car is low as f*ck had to drive the car up on bits of wood to fit the jack in..
Still need to change the filter, i didn't end up finishing the change until about 7:30 last night and i was tired as f*ck so i thought i'd do it next oil change.
Is it normal for my car to use 1L of engine oil in about 7,000km?
Low is when you carry timber in your boot to get into places, cant fit a broom stick under the exhaust box or spark on a daily occurance.
Couple of things:
umadbro?
My car is the same as yours except it's easier to get jiggy in the back
Couple of things:
Burn!!
there are a few manufacturers. Zspeed also makes them.
Haven't done any research but I have read about one of the versions actually hanging lower than the plastic OEM tray - so that's something i'd be wary of. I'd be keen on one though. I hate taking those trays off - on my mazda the bolts rusted on and I had to literally bend it out of the way, to get the oil filter out - which was a cartridge style meaning i was guaranteed to get oil everywhere.
Trays are a piece of piss. Off in 1 minute.
How?
Get your electric drill, and a bit set with a 10mm socket. Put it in your cordless drill, and remove all the bolts. Job done.
Burn!!
Hey you can get jiggy in the back of mine too, if you're 4 foot tall and feel like breaking your back
After 5 months of going back on forth on the idea i finally debadged my V today and couldn't be happier with the results, will try get sum pics up of the car next week when my holidays start =)
yeah but with ours you open a door and make sweet tender love. with yours you have to wait what feels like century for the seat to come forward then be lego man size and made of rubber to get into the back. 4 doors for more whores!!!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
