did some electrical work on the weekend - always so time consuming because I've learnt the hard way over the years that taking shortcuts and rushing the job will always cause headaches down the track. So i spent two days installing my reverse camera, and installing the amp. See pics below:
1. Alpine PDX-V9 - this is a 5ch amp that will run my entire system. It has 4x100wrms and 1x500wrms but birth sheet shows a fair bit higher numbers. It should pack a punch. But not only that, it's smaller and about half the weight of the mono block it replaces. I love it. I mounted it under the floor for a clean stealthy install. Took the TV tuner and mounted it where the Bose amp used to be, and put the Alpine where the TV Tuner used to be. Used all stock brackets, no cutting or drilling - so 100% reversible (the best kind of mod).
2. Even though it's a digital amp and runs a lot cooler than a traditional A/B amp - it's still a very enclosed location. Decided to install a little 12V computer cooling fan to extract heat from that compartment into the spare wheel cavity. It's hooked up to the remote wire so it comes on whenever the amp is on. Had to cut a hole in the plastic trim - but I reckon it looks pretty sweet and functional.
3. All hidden away from prying eyes and protected from flying boot fodder. . Maximum boot space. That's a win in my books!
(ignore spider grill thing - came with the car, and ironic because i'm hyper arachnophobic - that will be going once i decide on a new sub).
R6n350GT :
When you go for the dyno, do a run with and without the plenum spacer in. I did a test on my car and actually lost 3-5 kw through the mid range with the spacer in at 6psi. Spacers are designed for NA cars, I'm not sure they provide a benefit when turbod. Test it out.
R6n350GT :
I will do, wonder if i even have the old shorter bolts.. ? can i use longer bolts still ?
I thought g35driver had done dynos showing good for FI?
Cant wait to get it done !!
Turbo be arriving this week so its getting closer :)
Need to find guy that does custom piping in goldcoast
Yeah, I got told it was good for Fi too, bought one, and installed it on the dyno. Didn't gain shit, lost power.
You might be able to use those bolts, but you'll need to find some bolts for the middle 6.
What's the plan? Gt35 or t51?
HKS 3037Kit but modified so FMIC and 3582 CHRA inside the 3037 housing
Fully built engine with S2 BC Cams
Nice.
will be interesting, but surprised you didn't go to a T3 housing. I think the 1.12 housing in the kit is T2 isn't it?
i was talking to scotty about that, seemed there would be alot of fab work changing adapters, making room etc and didnt want to risk it not fitting :/
There would be.
At the end of the day - it has a 60mm gate for excess pressure, and should have enough flow to keep the GT35 spinning at a decent rate.
Dyno graph when done please :)
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
