I only got two passes tonight, best pass was a 13.9 @ 104mph, and that was with a massive throttle and a stab on the brakes.
Absolutely no grip whatsoever complete waste of time on spindly 235s, much much better times in it with a better set of tires.
104 is decent.
Yer, I'm not really happy but it was kinda expected. Anything before half track was a complete write off. With some better tires and soft suspension some very good times are acheiveable :thumbsup:
quick mcgoogle, 104 is approx flat 13.
Yer, I think a 12 is achievable. Will have a better terminal (>104mph) cause the first 1/3 of the track was spent limiter bashing and tire frying lol.
was good to see your r33 dude,
I ended up running my pb last night of 11.5 with 2.0 60 foot, so chuffed even touched 125mph on another slower run.
Thanks man yer it got alot of attention lol.
Yep I saw that run congrats man such a neat combo, I saw how pumped u were combing back through the pits lol
I reckon even the wedge would have a crack at that time :P
Might have to bring her out to the club drag day to put your dirty pushrod heap to shame
The car is capable of a low 13 / high 12, I just couldn't get it to the ground last night.
Plus I only got 2 runs, a bit more refining of the launch and we'll see where we are when the smoke settles
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
