Sorry - I fail to see how sticking a comic on your wing is "pushing the boundaries"....
I have some respect for these guys because of the hands on approach, but this car sucks teh hairy balls, and only appeals to honda fanbois it seems
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6671896
i think people missed the point of this car. Marty & Moog's season finale builds are always built with a certain amount of piss-taking (literally Moog's case) and satire. Just look at the TRD Laser and their Civic build.
In this case, the satire is less obvious because this is the fashion nowadays. But you can see the guys aren't taking this thing too seriously. Look at Moog constantly saying this is "what the kids are doing" and "the internet told me to" throughout the episode.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674783
I'm still hoping for a final season eposide where they build the ultimate bogan commodore...
Would be pretty easy & cheap to do I reckon.
1) Buy cheap VN commodore
2) Chop the springs
3) Buy a set of 20"chromes from bob jay for the back + retain a set of factory steel wheels for the front
4) Buy some clear tail lights off + Unit/Skin etc etc sticker off ebay
5) Drill some holes into the exhuast for that epic V6 noise
6) Add the chev bage at the back (leave holden badge on front) for the final touch...
Any other steps I missed?
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674792
2) Chop the springs
The chromies should be on the front of the VN with stockies on the rear for crazy single peggers or if you want to be a pro drifter welded diff for when you want to enter it in the D1GP
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674882
Thank you, I couldn't be bothered trying to explain it but you have done it for me.
I really enjoyed this episode and MCM is by far my fav channel on youtube
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6675704
I disagree. There were elements of satire in there but their closing comments and interviews lead me to believe that they thought that build was cool. They then add a bit of satire to the program so they can sit on the fence, see peoples reactions and if many people hate it MCM say they were just taking the piss. Episode is fail.
I like the fact they are from the area I grew up in and as a previous poster said the DIY aspect of MCM is great but they destroy cars that a young fella on his Ps would love and modify. Hacking a Subaru Vivio in half was a travesty. I would love one of them right now.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6676333
Pffft... At least there not getting drunk and wrapping them around poles. Do you have any idea how many second hand cars there are in the market?? They are entertaining hundreds of thousands of people and using a few cars out of the millions on the road.
Quite a few of their cars have been sold onto new owners who absolutely love them.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6677358
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
