Cleaned up the engine bay a little. Painted some stuff black that looked out of place.
The more recent pics I've seen, It Looks Awesomer!!!
And yeah, bit of paintage changes lots. (I did some of this recently too.)
Today I drove it to work and back (as is the norm) expecting to still hear strange noises from my fuel pump in the heat of the arvo...
None came. Could it be that yesterdays tweakage fixed it? Oh baby I sure hope so !!!
If so, I'll be like :bunny: and then :banana: with a :D
Edited by Not a Pulsar
Ordered some Whiteline parts for the Stag which were sent yesterday from VIC, and arrived this morning! You gotta love the posties working OT over Christmas.
Bushes, rear sway bar and front sway bar links.
Today it's stick the OEM wind deflectors on the GTR.
Painted them gloss black and now fitting them without the little metal clips.
Just over getting rain dripping in when the windows slightly down.
I hate driving with all the windows up! cos I'm a smoker......
Shut da fK up
Shut da fK up
HOW DARE YOU SMOKE IN THAT CAR
Weather strips FTW !!!
Smoking = each to their own (I do)
But I quit smoking in my car like 4 cars ago. The rule is, only on road trips more than 200 kms.
Poor GTR forced to passive smoke. Makes Baby Jesus Cry. :(
Swapped ignitor with the unit Richard gave me for troubleshooting........misfire still present, however only doing it under DECENT boost now (whereas last drive it degraded to the point of doing it anything above vacuum, as well as on take-off). I suspect the original cause is now 'fixed' by swapping out my ignitor, however I think it f**ked my plugs lol. Damnit.
Normal bearing/seal etc gone in the old pump, nothing major.
Next SAU track day is probably the next outing.
thats good then
Installed poncams in my car today. It didnt take anywhere near as long as i expected. sounds mint and all ready for my tune tomorrow :)
which poncams?
interested to know the power figure?
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
