I Grabbed some from OTR for my Nismo LMGT's. Could have bought Nismo nuts but decided to get some alot stronger for less than half the price.
Dont under estimate the value of a good set of nuts. I prefer steal (lol). Give them a call and you'd be surprised about the price :).
Unless your after 1/100th of a second I'd buy something that may be lifesaving over wheight saving.
You also couldn't go past Rays. They make great rims so you can expect their wheel nuts to be great too.
i have nismo wheel nuts.
i have thrown alot at them, and never a problem.
so long as they are torqued correctly when put on.
also, on your rays front, nismo also make quality items, so their wheel nuts should be of no exception, which, they are not.
ot, bought an engine and machined flywheel for the hilux this arvo.
$2 for both.
gotta love ebay.
motor has stripped dizzy drive gear on cam, not worried, as it will be replaced.
Anthony, thanks for the offer to help pull my dash out. I Got lazy and didn't want to spend several hours on it learning as I go.
So I got Audiotech on the job today mate. After things like glove box, centre stereo and consoles removed, apron under the steering wheel
Turns out that 2 small screws and 2 bolts/nuts hold the dash itself on. Amazed !
Upshot - my existing dash will be available by the weekend. If you want it come get it Friday/Saturday (and pay later :))
I already got a dash off you bro! haha. well im glad the new one is in. Let us know if you ever need a hand. Out of curiosity how much is it costing for them to do it? i have yet to decide on if i will bother to do it or pay someone. Though my job runs out in 3 weeks and im still trying to find a new one... how fun. Richard i still owe you $150 from the other dash. When i get a new job ill come round with what i owe you. I also can't find that fking boost controller.... I think i have gremlins stealing from me.
Note to self: new pod filters, Cams, Haltech or z32's (yet to decide) and i said my GTR was finished in the engine...
I could never have been so wrong...
Shite - thats right. Hmmm
Anyone after an R32 dash. Suits all 32's
Has a minor bubble' and a plug to cover a 5cm hole. All in all it looks good........just not perfecto
I have all of the Blitz Dual SBC stuff except for that display/control :( (this is good stuff).
Haltech does all the shite now :D
Looks tasty. :thumbsup: Did you pull them off to do it or just leave them on and mask everything?
Wanna do this too, Black with Red NISSAN. :D
I left them on and masked everything. I didn't want to bleed the brakes.so took a shortcut. It will look better if you took it off and the clips I'm yet to sand paper the Nissan out and paint it silver or white.
buy haltech.
i have pods for sale.
m's elbows with unknown filters.
sitting in the garage not doing much.
I have some Apexi pods for sale too if that helps you at all Anfanee :)
This one:
http://www.nengun.com/apexi/power-intake-gtr
Came off mine when I went to single turbo. You can have for $100.
This one:
That would be great, Want to bring them with you on Sunday and ill grab them off you? ill scrape $100 from the missus =P
Finished and installed my DIY Pod Shield. (just needs some rubber round the edges.)
Amazing what you can do with a coat hanger, texta, cardboard, perspex, a renovator tool and a heat gun. :laugh:
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
