Do it on the side until you start making to many clients and turn full time :D !
Would a carwash place (Machine thing - like the ones at the petrol station - Likes Waves at Gunners) will that damage my paint work? I have a few bits of paint scratches and 1 rust spot - would a high pressure gun / carwash machine peel the paint?
Edited by Jeremy90
Sinister, you put up a number for a bloke from Tire wholesalers a while back, for mike or mitch or something? Well actually have money for tires now and I can't find the number.
Thanks mate. I'll become a member soon, just so I can throw the '33 down the tarmac a couple of times. Found some PZero Neros for cheap, so they will last me until the end of the year...
Started stripping it, and removing obsolete bits. (aircon pump finally gone)
In preparation for new injectors, timing belt etc, waterpump, Z32 afm, fancy timing gears, Nistune, radius rods, and a clutch.
And some little things like a battery isolator, re do the gauge mounting, some more stickers etc.
Wow - getting stuck into it Michael. Rip it all out maaaaate
No aircon ?? - you setting up a track car ??/
well I did the usual when I got back from Belco ghetto (washed/polished the cars).
Then decided I'd do something really simple - remove the cabin rear view and paint the back of it black.
Fark me while removing I broke the friggin mirror in it didn't I. *&^%$ Live n learn....
Oh oh oh - the bonnet came up like black glass today :D
Spewan! (mirror)
Aircon just made it overheat, but i am making an extinguisher bracket for track days.
Wouldnt take much more though... some brakes and a seat.... hmmm. I need to keep it road legal. And have a loud stereo.
If i was going full track car id strip it to nothing, then build up with a plan. One day.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
