sorry man I cant help. But you have the guys who will sort it out
sounds like you may have to re-visit the install of the GB and have another look at the clutch :/
new gearbox or new to you ? State of the clutch ?
After thought, heard a few guys chatting last night. What about electricals/sensors..
New to me, seems fine. I can go through all the gears with no problems as long as I don't hit boost.
The clutch has only done around 10,000km as my mate (same guy) changed it when I installed a new engine.
Prior to this it was working perfectly.
All the sensors were all plugged back in and were in better condition than they were on my old box.
Were the sensors put back in the correct spots.
Are they coloured ? and do they carry different voltage signals ?
I could be totally wrong as seriously I don't know what I'm talking about - lol
just listening to a different conversation...
I think we may have discovered the problem.
On the new box, the front cover shaft was welded back on in the past and we think that the weld isnt allowing the
thrust bearing to go back far enough resulting in the slipping of the clutch (driving like the clutch pedal is half pressed in)
So now I need to try and source the part number to get a new one as the one on my old box has snapped off.
Thanks anyway Richard :)
Trying to keep the bottom list short, but its hard.
"Love the beast" or compulsive modifyer?
Done
big fmic
new kingpin bearings
rb 25 turbo
3" exh w bell dump
one piece tailshaft
podfilter & cold air box
strut braces front and rear
Neomax adjustable coilovers
adj upper arms front and rear
DW tracton rods
Hardrace radius rods
DW hicas eliminator
solid cradle bushes
solid steering bush
oil catch can
thermo fans
Autometer oil, water, fuel/air, boost guages
voltmeter
volt stabilizer
yellow jacket coilpacks
stereo, amp and speakers
new parcel shelf
approved child seat strap mount
rear view camera
sports steering wheel
immobiliser
engine damper
heavy duty clutch
battery in boot
oil cooler and filter relocation w thermostat
removed aircon
Nismo shift knob
electric heater
GTR front bar w n1 vents
Nistune ecu
cam gears
timing belt
water pump
rear wiper delete
To Do
fix harmonic balance
tap temp switch hole
fix intercooler piping
fix immobiliser light bezel
fix pod & cold air box
radiator and oil cooler ducting
braided brake & clutch lines
fire extinguisher
fuel pump
injectors
z32 afm
tune
pwr steering cooler
improve head lights
boxes in boot
heatsheilds
dash
fuel cooler
diff centre?
good thermofan
drivers seat
use stickers
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
