go on, let me in your 32.
last one i sat in still isnt running...
I lived with Richard for 18 months and never got to go for a ride :(
Haven't gone for a ride in his 32 either!
What did I do to my car today ? Ummm - picked up a parking fine.
Went for another spirited drive after work out through Tharwa and looks like I' need my clutch rebuilt/replaced now.
Living life a quarter of a mile at a time. Tis expensive lulz !! Launching can = lunched :P
having an awesome weak. Caught up in 3 queues due to accidents, 1 parking fine and now a lunched clutch.
Well I shouldn't really complain as the OS giken twin plate has been in since before I bought the GTR 10yrs ago.
You have to expect to go right through your drive train from engine to rear diff over time. Shift the power to find the next point of failure.
GB next ? yes it's likely.
Last night I took the gearbox off again and replaced the front cover allowing the thrust bearing to slide all the way back, so no more slipping clutch :D
Today I got a buff on the car and got my drivers seat back from my upholster. Wont be able to fit it today as I just got home from ED after slicing my leg with a box cutter :D
Edited by Zippo8
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
