^take pics and post please
What the - Show n Shine in N.T.
I visit the section every now and then and not many if any SAU people post :(
Was a really good day. Amazing how many awesome cars are in such a small town!!
Here is a sample =)
View slideshow
http://s215.photobucket.com/user/sexychef77/slideshow/Alice%20Shanons%20Show%20n%20Shine%202013
Go to album
http://s215.photobucket.com/user/sexychef77/library/Alice%20Shanons%20Show%20n%20Shine%202013?sort=3&page=1
Edited by Sklyn
Happy with it? How was the drive home?
Yes, very good. Normal clutch is awesome to have again.
Sounds a bit different too.
Oh and Sklyn, be ready for some freezing when you get here.
I just hope the new house has good heating....... =)
Do you notice much difference between brands of fuel there?
I will only use BP here as the others are noticeably crap!
In the 2 and a half years I've had my car, Every single drop of fuel has come from the Caltex at Kippax. (Vortex 98) - Woolies Discount.
Never had an issue.
Slideways - be carefull at first or you maybe kicked in the pants.
Roads are greasy at the moment as it's only just started to moisten up so the oil will rise to the top.
18-21 PSI :) more boost is not always a good thing. Upto 21 should be optimal and safe.
Did you have new turbs/wastegates put in during the build phase ?
Whats your ECU again ? (Nistune/Power FC)
Edited by Sinista32
Pretty sure it was the Cleaning of the Airflow Meter that fixed that. :thumbsup:
yeah that thing.. haha I'm pretty screwed. Sat down on my couch and now exhausted from 2 days of non-stop madness !
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
