chucked the stock struts and exhaust on my new car for rego inspection and discovered that i will probably need to borrow some wheels because the front wheels now sit well outside the guards at stock ride height :(
Anybody help a brother out with stock evo wheels that have some roadworthy tyres?
Checked tyre pressure, topped up coolant, oil, power steering, reattached some plastic cover dealy up inside the drivers rear wheel arch and made the whole thing Far Less Dirty than it was.
I like a pic I took.
  • Like 1
Trial fitted a 32 bootlid with a 34 GTR wing. Sounds weird and the purists wont like it BUT....
I think I like it. Especially with the black bonnet.
Will get it sprayed the same colour as the rest of my GTR.
(It's currently KL0 Silver).
So the plan this weekend is to change the spark plugs, as I have never done this before, can anyone suggest a good writeup of how to do it?
Have you used the search feature? There's usually some pretty good guides on the technical sections of these forums.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
