But it is fixed now? That is a rather Random thing to happen. Unlucky but LUCKY. :D
join NRMA roadside assist. $90ish / year, you may not use it but if you need, they HELP.
I have mostly used them for flat batty but I've called them for what turned out to be : cactus fuel pump, ignition module, 2 new Batteries etc...
I even got a tow off one.
Worth it. :yes:
  • Like 1
+1 for NRMA their roadside assist has been awesome to me over the years.
The guy who came out last time was excited to see the car and that it wasn't a straight forward boring case for once!
While raising my coilovers to a legal height i discovered my right CV boot was cracked. Has anybody had a go at replacing CVs on a r32 GTR?
can be done.
measure the outside of the shaft section, and cup section.
approx length, then take to repco and get the to match by dimensions.
thats how I got my front boots.
try and get the cv band tool if doing them yourself.
about 30 bucks from memory.
love nrma.
I keep membership purely on the gtr.
cheap tow.
20kms free, and ive had it towed twice in 2 years.
Took Rosie in to get coil overs done - missing bush in one of the coil overs (Couldn't do it) so requested to do brakes - They didn't have time to do it. So got Rosie back with no work done ($50 labour fee so pretty much paid $50 to park on the southside). Few days later got a quote on all the work that needs to be done due to tare and wear, as follow; I guess with the below all done and fixed that's everything for suspesion and steering also, all the parts that are being replaced are from factory from my understanding so 15 years worth out of a part is fairly decent I spose:
LAB 7.00 LABOUR $100.00 $700.00
WA - FOUR 1.00 FOUR WHEEL ALIGNMENT $90.00 $90.00
SPF1811K 1.00 BUSH - CONTROL ARM UPPER/ OUTER F $205.75 $205.75
SPF1484-21K 1.00 BUSH - SWAY BAR MOUNT - FRONT $22.67 $22.67
2.00 SWAYBAR LINK - FRONT GENUINE $68.00 $136.00
54618-85E00 & 54668-85E00
2.00 STEERING RACK END - FRONT - RE844R $39.91 $79.82
2.00 TIE ROD END - FRONT - TE926-12 $29.20 $58.40
2.00 HICAS BALLJOINT - REAR 55154-30P01 $155.00 $310.00
1.00 HICAS LOCK BAR & TOE ELIMATOR $325.00 $325.00
SPF1485-18K 1.00 BUSH - SWAY BAR MOUNT - REAR $27.53 $27.53
SPF2667K 1.00 BUSH - SWAY BAR LINK PIN KIT - REAR $24.69 $24.69
ENV 1.00 ENVIRONMENTAL WASTE DISPOSAL LEVY $5.00 $5.00
WSS 1.00 WORK SHOP SUPPLIES & CONSUMABLES $8.00 $8.00
TOTAL: $2,200
HICAS LOCK BAR & TOE ELIMATOR - the toe elimator might be some cash I'm guessing? I'm not sure. I asked him about not wanting my HICAS locked but he said he still needs that kit due to repairing the other stuff on the HICAS which the kit provides.
love nrma.
cheap tow.
That is all I use them for, 4 times in 6 months to the workshop and back. You can add 10km to the 20km free for $10.
30km free towing ;)
You could do half that stuff yourself with a bit of help I reckon. Whn I had a 33 my hicas lock kit cost 150$. You shouldn't need a toe eliminator kit, I just had to get a wheel alignment on the rear to remove the toe created by the lockout kit.
Have you actually got under the car to have a look at some of the bushes and suspension parts they have said need replacing to see if they are actually rooted?
Yh you can probably do more than half of it by yourself im happy to help you if you need any. R34 dont need to get their Hicas locked as theirs the electric one (Super Hicas) not the hydraulic one.
http://nissanskyline.6te.net/HICAS.htm
You could try a second look and quote from Capital Steering and suspension. (as you know I don't trust anyone)
Looking at the labour and parts it appears to me that your Skyline has been thrown around. a bit.
It's steering and not really suspension, with a bit of stabilisation parts thrown in.
You could take a look with them while they point things out to give yourself comfort that the parts are farked.
I've had to replace basically everything suspension wise on the GTR and it wasn't cheap but a lot of those things were more expensive than what I paid to get things done.
I think great to get all that stuff refreshed on such an old car.
My GTR is an 89 model and when I bought it in 2005 the first thing I did besides get a major service done was drop like $3k on the suspension. Well worth it but I'd just double check these prices that you have :)
  • Like 1
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
