Old gearbox mount is starting to peel off the rubber.
Looked for the cheapest fix so i put in one of those GKtech solid mounts.
Holy crap it makes the whole car rumble, and the gear whine is full on! And thats only backing up the driveway! :O
Maybe a bit harsh for my liking. I think its more of a full on race car thing.
Braided clutch line in, bit of a pain to bleed it.
Have to test drive and see how it goes.
Edited by D.I.Y. Mik
Solid gearbox mount is too loud, has to go.
Bad shudders under acceleration, some problem that i can now feel cos of the solid mount.
Must diagnose and fix.
Richard, nice wheels, and i have to give back that boss kit sometime.
Replaced my left front upright because old one had damaged eye bolt that the coilover mounts to. Gave everything a nice clean ready for some cruise tomorrow :D
Rob esp are good with safc's so is auto tech hume albeit more expensive
Auto tech is Hume 100% just got my car back from them after being there a week. I'd say I'm happy with Ed's tuning and service. Car is running good. Ed tells me he don't really like haltech but he tuned it so well. I'd defiantly recommend Ed and the Autotech team with out hesitation.
After getting my car back id just like to tip my hat to Adrian and the guys at ultimate tunes for the finishing touches on the GTR. It drives and feels incredible. It has never ran so well. Couldn't be happier.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
