280 at all four at the moment. It goes in next week for the final tune (for the day) and Adrian expects to see 310-315 out of her.
You happy with your 32 after getting it back? How many kW's?
Wait, you just can't climb in the ring with Ali 'cause you think you box!
And I need them by TONIGHT !
Yeah.... its like, "i cant believe its so simple" most people just never have a look. Good on you, now your going to save some cash. :D
Spark plugs require more parts coming off, but youll see its real easy.
Nuts and bolts are a simple principle, thats 90% of the car. Ive learned most of it just by pulling it apart and having a look.
Today i cleaned, degreased, and wiped with metho. Under the bonnet too.
My engine bay was soooo filthy, now its a different colour.
Now i need to give it a light sand, cover up the engine, tape up things and paint black.
Going to do the upper part of the inlet plenum, the crossover pipe, and the cam covers black too.
Just replaced my first fuel filter. ahh it feels good this self servicing =)
can't believe people pay people to do that!
next, sparkies..
Good onya James! Your car will love you for it. :D
She's gonna look sweet Mik!
Today I witnessed my Timing Belt and Water Pump being removed... Might get it back tomorrow but maybe thursday.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
