what material are you using?
I'm thinking about using tinted perspex (cos it looks good) with some heat shield lining inside.
Also, are you going to include mounting brackets? and where? or does it just sit in there ?
Pros and cons, Hints and tips of perspex:
Its very brittle. So you need the right saw etc
Perspex dust is very flammable
It can be easily moulded to most shapes.
Its like a thick clearcoat, so paint the inside for best effect.
The heatgun is ESSENTIAL.
I cut it with snips now, no dust, no cracks, but its gotta be HOT. You want welding gloves.
If you find its warped or has an indent, you can heat it till it goes away.
If you heat it more it goes like rubber, and you can mould, fold and stretch it. But its tough and needs force to stretch it.
And its very hard to get a nice sharp corner.
Heres a tip for folding corners: Drill the corner first then cut to the hole. If you dont, it WILL crack!
post-89755-0-61958400-1381306684_thumb.png post-89755-0-09564000-1381306705_thumb.jpg post-89755-0-41692900-1381306728_thumb.jpg
  • Like 1
Finally got around to making a proper bracket to remount the washer bottle and extended the wires for the plugs so now I have a functional rear washer. I tried to fit the ac thermo fan as mine was missing when I got the car and found the reason it was not on there was because it fouled on the intercooler core. I'm back at work tonight so next break I will find a thinner thermo fan and make some brackets for it or try and mount my intercooler a bit further forward if I can.
tin/colourbond.
check in the original wdydtyct thread in wasteland.
will post more pics when done.
Fitted my new OEM headlight switch. headlights work properly again. Also hid my turbo timer as i never touch it (all programmed in no need to), moved my boost controller (soon to be moved again) washed, wax outside and cleaned interior. Need to go get another headlight globe as the two i have are different colours :verymad:. Polished my exhaust. Waxed my wheels. Also started drafting up new POD filter mounts and a pod box until i pull the PFC out and throw haltech/ARC box in.
Oh also detailed someone elses car for the first time. Partners partens car for a wedding. Used a mild cutting compound for the deeper scratches and then the usual clay bar etc etc. Looks great apart from the fact i ran out of wax : | so on thursday i have to re do half of it.
Also note to self: Silver cars are HORRIBLE to detail in the sun. Even with good sunnies on i swear ive lost vision.
  • Like 1
Yes! You comin' ????
Today I jump started a Crapped Out Commonwhore for a workmate and washed the Wrong Car Micra.
Also discovered why the Crappus Work Van (Express) is overheating etc...
Ummmm... The overflow Bottle is Dry, the Radiator Core has No Water on it when you look inside plus it's Very Rusty Coloured in there and the oil doesn't even show up on the Dipstick.
Could cause some issues me thinks... Aint my Baby. :/
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
