Now my car goes, i can enter. Entries close 8pm tomorrow.
So scrutineering starts at 730 am,
If its got a good mount, yeah. Thats what mines lacking. Duct tape wont pass.
Gus, it was $1890 fitted, with some, not all, new bearings and seals.
Fk i love these wheels!
:D
Edited by D.I.Y. Mik
Man... Car looks Awesome! :woot: Amazing what Some wheels can do.
I take it that it is driving better now with wheels / diff etc?
Cam has a sucky cup and will likely stick to a clean panel but certainly sticks to the inside windscreen Very Well.
So what time are you getting there? 7:00 - 7:30? I can do that. (starting work at 5am lately so 7 is nothing)
ill be there at 730
but i have to enter first, ill make sure to tell you if i get in or not. :thumbsup:
Ive only just done the figure 8s as instructed to get oil through the clutches, it feels weird, i havent driven it for 2 weeks.
A few more drives and ill see how good it is, my technique is to work your way up to it gradually, and you wont stack.
Spent the day replacing the last few old, dried and cracked joiners for the turbo outlet and crossover pipe and replaced the low pressure power steering lines.
Half the day was spent driving around northside to a few transmission places to try and track down some 5/8 trans hose, ended up having to go out to enzed in fyshwick to get it. I think i have fixed more issues on my car since it's been off the road for the last few months than I have the whole 2 years I have owned it.
Wow... that diff is good!
Very hard to break traction now, the federal rsr help too.
Now i can use more power!
BUT it stinks of fuel, somewhere from the back, better fix it before it bursts into flames.
fuel tank is out, pretty easy to do
heaps of dust and crap all over it
Looks like the leaks are from the filler or the vent line or the filler overflow line.
anyway all hoses are being replaced and ill have a look at the filler tube gasket.
a fresh coat of tar underneath would be good too
If i turn up for scrutineering reeking of fuel, illl fail for sure.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
