So the last few weeks i have been getting my car ready for another attempt at Dickson.
Replaced all exhaust gaskets
Stuck on my English translation "engine tune up sticker", Tyre placard and Jacking procedure stickers.
Replaced Rotors/Pads
Printed of a scanned copy of the Wheel track measurements from a workshop manual.
1.They did not accept my print out of the track measurements because it was not a genuine nissan document, I did asked them to ring nissan and confirm and they said its not their responsibility. I asked if an genuine Australian workshop manual would be sufficient, But even thats not good enough! apparently the measurements might be different on the JDM/ADM workshop manuals.
2. showed my new engine tune up sticker and they were very surprised i actually found one, The oldest car inspector made the comment "whats that for"
So i passed on everything but my track measurement problem
It looks like i have to find a set of standard GTR wheels to get past their stupid game
Anybody have a set i can please use?
Or something 16x8+30 225/50/16
My heart goes out to you man. I just finished playing their games - and it was not fun. I think I had the difficulty on Expert at the rate I was hassled. But on the actual passing they were a little lenient - they all remembered me to which I thought would be a bad thing.
Anything GTR I won't be able to help - but all the best ! Thursday 9am seemed like a good time to go through haha
Thats bullshit Jimmy,
I had troubles like that on my engineers cert for my old 4wd but thats because it has to be what's stated on the engineers cert.
If the car is complied then its complied to ADR specs and a JDM manual means shit, and as long as the dont come out past the guards or foul on anything then thats ok, on a car with a tare weight of 1290+kg you are allowed 2in or 51mm bigger rims, also the track can't be narrower then factory.The maximum legal permissibile increase in the vehicle's track width in most states of Australia is 25mm and others 26mm. Most states subscribe to the National Code of Practice, which stipulates a maximum track increase of no more than 25mm.
Edited by gtr judd
#@JimmyS I found these, not sure if thats expensive, but I can pick em up for you
http://pages.ebay.com/link/?nav=item.view&id=171166032464
Edited by gtr judd
Drove to Cooma and back, first decent highway trip in it, nice and smooth, no overheating, seems all good.
Popped out of 5th a couple of times, does this in third too, feels like the detent is worn or something. Maybe during the bodgy conversion from auto, the shifter hole wasnt cut right. must look closer.
Yes, Cooma Run = FUN! Thanks Mik!
Got my Magnaflow Muffler on, Love the look and the quietness.
Surpirisingly it took away all exhaust drone even though it's as straight thru as the Canon.
post-78856-0-64567500-1383985703_thumb.jpg post-78856-0-82910100-1383987382_thumb.jpg
All flanged up so I can chuck the canon on anytime. ;)
  • Like 1
They would definitely do the job, ill have a look around for another week and see what else may pop up,
MiK - what sort of exhaust do you have ?
Maybe you could come and have a look at what I have and see if your interested (bring wallet)
Being 32 either spares should fit. :whistling:
I have jjr bellmouth then 3inch cat then it gets nasty, muffler? dunno
Do you have 3 inch cat back system?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
