About GTR boxes...
I look for RB25 engines and boxes as i want to do an upgrade one day. One thing ive noticed is that GTR boxes are about half the price of an RB25 box.
Usually about $900.
Why are they so cheap?
Im thinking of using one, if i can make it fit behind an RB25
Its always garaged , maybe soon we can go out for a cruise
Pretty sure I'm puttin a day permit on for this formal run/cruuse. Are you coming? We can head out and cruise together
GTR 32 boxes have smaller sinchro's. So if you go for a 33 pull type there is more expense in bits n pieces. (not just a push to pull conversion)
Could explain price difference.
Jimmy's GTR is really nice. Saw it for the first time today.
There was 3 at Shannons BBQ :D
Drivers window is stuck in the down position and swapping over to my old window module won't fix it, Half the functions on the module work, just not the window section. Off to the autoelectrician I go, I think theres something wrong with my door loom.
SkyWagon got her Front Shocks and Harder/lower Springs today. (Thanks Mik for the Tools!)
With other commitments thrown in, it took ages and especially those damn Bigass Nuts on the struts, what a bitch to undo, plenty of swearing but the ride is Sooooo Much Better. I think it's a whole 5mm lower. :laugh:
Tomorrow I'll do the Rears. :D
She also got some new wheel nuts, Center Caps, Valve caps and a Nice SkyWagStag sticker for the Kilowatts.
Just need to fix the exhaust leak and adjust the handbrake and we might be close to Rego name transfer...
post-78856-0-22616100-1386419151_thumb.jpgpost-78856-0-19450900-1386422407_thumb.jpg Black is Stock.
Got my inspection on Thursday.
Played around with the drivers door today and finally got to it close correctly.
Heading over to shanes place tomorrow and raising the coilovers.
Then all I need to do is cut the wire for the hicas light on the dash.
Chuck some roadworthy rims/tires on the car (I guess yours are gone Rob :/ )
Also put a stock exhaust on there.
Hopefully the list I get back isn't too long
Ohh and my R34 left Japan on Monday :D
Yeah Sorry bout that. :(
I might try to get some more tyres for the lendings...anyone wanna chuck in?
Take your cluster out and remove the bulb for hicas, no chopping.
Northwest in Fyshwick are pretty good for 2nd handies. (not the other kind of handies) :D
The spares that are now on the Wagon are 225/45? R16 and have passed several times. ;)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
