Went over Dickson today.......
FAILED lol which I knew I would. Got kncocked back on minor things
*horn wasn't working (which it did on the way there)
*upper inner control arm bushes
*radius rod bushes
*1xCV boot in front was split
*both rack boots were split
*tyres
And an advisory on noise and height. They are both right on the legal limit
So not too bad at all
Looks Tasty Anfanee. :)
Today I received in the mail...
An Old School Metal Datsun badge that may or may not end up on the SkyWagon and a Spare R31 Auto ECU which may or may not fix the intermittent Fuel Pump Priming issue... Both off Ebay, both very cheap.
I cut up, painted and fitted a piece of PVC pipe to straighten out my air intake.
Played multimeter games with the TPS to try to fix an acceleration flatspot.
Disassembled and cleaned my spare AAC valve and installed it, had to bleed the air out of the cooling system, fiddled with the TPS some more and checked timing again. (still needs more TPS fiddling) :/
Nice straight intake (removed the weirdass bends)
Now with ^^^ GT badge in grill.
Clean vs Dirty AAC valve.
dirty vs clean where the AAC bolts on.
post-78856-0-75338900-1389860946_thumb.jpg post-78856-0-42800400-1389860970_thumb.jpg
something very interesting just happened
Dad comes home from work saw me working on my car asked me whats wrong and did i found out what was the problem with the car, i told him off that its not his business and its my car i will fix it whenever it breaks down and i dont need his help. Next minutes he packs all his tools and locks them :(
Lucky i did managed to get a few things off the car. But now i need to find a new job and buy some tools and finish my car.
Here are some pic i took of what i did today
im yet to use dads tools, im sure he would do the same... I don't get why he spend so much on his tool and tool box, he owns a brand new fiestia ST and doesn't work on it, tho he did mention something about restoring a 1955 f100.
post-127489-0-84733600-1389865310_thumb.jpg this but chopped and matt black...
Edited by ..::R33GTS-T::..
I must admit. If my son talked to me like that I wouldn't just lock my tools up. I'd be packing his bags for him and kicking him to the curb :P haha
I feel your pain about a new job. Hard to find decent work with a decent team. Goodluck with the car - hopefully it can come to the next cruise.
Agree with you RoseBud. :yes:
Hmmmm... Make peace with the Old man mate, He has the mechanical Knowledge, the Tools, the ability to make life hard for you and Your Balls in a Vice. :P
as my Dad said many times over... You live under my roof, you live under my Rules.
  • Like 3
So the next question....
Do i order new seat covers with the money from the bike? :woot:
these ones...
nengun-4323-06-nismo-skyline_gtr_r32_sea
Are they leather seat covers? Or an actual leather seat? They look nice regardless.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
