Changed SkyWagz' Diff Oil. The old was OLD! and definately a little low.
Nulon SAE 90 took it's place. (glad I bought a 4L bottle when I did the 33) :)
I wonder if the diff will whine a little less now? I'll let you know. ;)
Spent alot of time (Fiddly F**ker!!!) replacing upper and lower trailing arm bushes on the Wagz today.
Old ones were fairly goosed so Nolathane went in.
Was going to do the Panhard rod bushes too but meh... I'm over it. Another day.
Feels alot more solid and steady in the rear and yes the Diff Whine is still there but definitely better since the oil change yesterday.
Guess the new bushes may not help with the whine though. :rolleyes:
post-78856-0-70311300-1399723931_thumb.jpg post-78856-0-73560600-1399723929_thumb.jpg post-78856-0-54626100-1399723927_thumb.jpg
Rob,
Squirt in 60-80 mls of Pro-ma. Must be someone in CBR sells it.
magic stuff (unless it's a LSD then not a good idea)
This stuff? --->> http://www.fueloiltreatments.com.au/technical/MBL8_oil_additive.html
Sounds pretty good. Thanks Scott. :thumbsup:
I may try some Nulon G70 --->> http://www.nulon.com.au/products/Specialty_Products/Manual_Gearbox_and_Diff_Treatment/#.U28voIGSyuk
but The Nulon oil I've put in is definitely an improvement. It actually sounded a little bit better again today.
I put nulon g70 in my transmission a little while ago and it definitely reduced some of the cold 2nd gear crunch.
Realised after putting it in that I'd only put in half the amount I was supposed too as well. I presume it would only be better with the correct ratio
I got that result ^^^ in the 33 just by putting in Nulon Gbox oil.
Haven't tried the G70 in the 33 Gbox or Diff yet.
Today I resoldered a dodge connection on the Drivers Front Speaker in the Wagz and put the charger on the 33's battery for some love.
Pulled the Whole Steering column out of the Wagz today and replaced the old Bushing with a Fresh SuperPro Bush.
post-78856-0-12031700-1399870038_thumb.jpg post-78856-0-43480600-1399870041_thumb.jpg post-78856-0-11314400-1399870036_thumb.jpg
Steering is much more direct. :thumbsup:
Found where the Immobiliser unit is hidden, tightened up the accelerator pedal bracket as it was quite loose and took some Slack out of the cable with a couple of Zip Ties. :)
Also hit the Grey Interior Rearview mirror with some Black as I did on the 33.
Much Nicer.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
