mine is highflow OP6 (GT2871) on 25Det Neo - 245rwks at 17psi
not sure there is much more in them to be honest.
best go for optimum not maximum (bad shit happens when maxxing)
uncertain what E85 can achieve tho
Yeah I would prefer to be running a more optimum boost through my turbo but it wasn't possible because it was supplied with a 20psi actuator.
I'm going to be pulling it out of the 33 and putting it into the 34 when I get home. Before that though it's going to get sent to hypergear to get a lower psi actuator put in and upgrade to his most recent model of it.
Nice wide powerband by the looks of it. Thats faster than a big peak. I dont think peak power matters, its the band of revs you use from gear to gear that makes you go fast.
Radius rod brackets fitted, removed brake backing plates and fitted new air deflectors.
Bleeding brake fluid as well while im at it. Those vacuum bleeders dont work because it sucks air in through the bleed nipple thread and i know there is an air bubble behind the nipple now.
A remote controlled foot on the brake would work the best................... Invention time. :yes:
post-89755-0-07011500-1400986583_thumb.jpg post-89755-0-75588100-1400986603_thumb.jpg
Edited by D.I.Y. Mik
Saw the Green Beast today, it's gonna look Amazing when assembled and shiney. :yes:
Did some more Dodge touchup paint patches today, painted the inside of the front indicators with Chrome paint for extra Reflecting Brightness, Cleaned the inside windows better and applied a few more stickers, also stuck down some of the loose window seals with some black silicon.
Went for a little drive and got some Shiney SkyWagon pics.
(also, some dude in an orange ute did some circle work right in front of me.)
post-78856-0-53445700-1401007644_thumb.jpg post-78856-0-98909600-1401007673_thumb.jpg post-78856-0-86597600-1401007659_thumb.jpg post-78856-0-16349000-1401007652_thumb.jpg
Today i adjusted my hand brake and checked the brake pads on the rear and while i was doing that noticed that one of the bolt in the driveshaft i missing so fixed that and checked all the other bolts at the same time
Good stuff Chris wasn't game enough to go to Sydney because if had an issue I'd be stuck.
Thanks Bryce. Yeah I have family in Tascot which is only 10 minutes from Jez's workshop. So I drove up Friday night and stayed there which was convenient for me
Did a skid in it.
Doesn't appear to be any more broken than before.
success
This is a damn fine thing. :D
What did I do to my SkyWagon today?
Drove it and admired the Shiney.
oh and got a compliment on the cleanliness.
Washer bottle fitted, new sway bar bushes going in next, old ones are out.
The front D bushes... i just put all that stuff on, only to have to take it all off again to get to it. Doh!
Window net brackets gone, much safer, but i have big gaps chopped out of my trim.
New (actually second hand) ones arent easy to find, maybe ill just fibreglass and re-cover the old ones.
Tried installing a Cusco lower triangle brace (goes from caster arm mounts to front crossmember).. in the process managed to fk a socket and round the bolt.. so will be buying a mini butane blow torch tomorrow and getting rid of those stupid bolts.
Also in the process of fixing up my dodgy cooler piping.. ahh wish I could drive my car again :( Had to put the trickle charge on the battery today.. sad sad
Adjusted the drivers door.
Passenger door is fine. Which is nice, cos i had to take off the guard to do it.
Took a chip of paint off the edge and a small scratch up top.
Oh well sht happens, im not really bothered, considering the old paintjob had about 6 chips and 3 or 4 scratches.
Might touch it up with a little brush, maybe after its buffed, dunno, it doesnt really matter. Scratch might buff out too.
New rear swaybar bushes are in, front were wrong, so im waiting for them.
New shift detent springs ready to go in, and brass bush to go on the shifter, but i sealed the top up with something real good, it doesent leak anymore..... but i cant get it off. Tme for the prybar and mallet.
Fitted some new wiper blades, going the Trico aero style ones this time around. Going to be a big improvement particularly from the passenger side one that I had was bent!
Picked up a new jump starter pack at the same time cause was 50% off today. Now I'm cooking Pete's lunches for during the week and I've convinced him to polish up the windscreen with Rainex :D
Was looking at the aero wipers today.. what's the quality like for the trico ones? I was actually looking to get some bosch ones, but can't find any in Canberra..
Yeah I went hunting for Bosch but had the same problem with finding them in Canberra. Only place I didn't check was Auto Pro but no dice at Repco, Supercheap or Auto Barn.
I'm not too fussed though, good mate of mine has 2 cars with Trico on one and Bosch on the other (same reason he couldn't find them at the time of buying the second set) and said he can't tell the difference between them.
I'll let you know what they're like next time I get caught in the rain! I have some bugs on the front bar from my last road trip but GTR is mostly clean so I didn't wanna test today!! :)
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
