Sadface. I wish.
I hardly even drive my GTR on town roads. Spends more time @ Ultimate than it does @ my place.
Speaking of it's going back in next week or the week after. lul.
Spent all day on the VC
It's in pretty good condition
except no brakes :/
- Front callipers seized so got reco ones, rear wheel cylinders seized so got new, master brake cylinder cactus got new, pads worn so replaced, front discs needed machining and bled brakes - All fixed now :)
- then degreased bay, washed, clay bar, polished, polished again.
Tomoz will wax x 2 and clean engine bay and paint a few minor things back to new looking and then clean interior
Then full service and drive :D
Not that im any better....... :laugh:
post-89755-0-36612200-1406858051_thumb.jpg post-89755-0-14085200-1406858067_thumb.jpg post-89755-0-59803500-1406858088_thumb.jpg
Crappy photos at night but you get the idea.
$25 on ebay, You can use the controller or just hook up the colour you want.
Thats what i did, just cut a length, wired up the earth and the green, then plugged it into the boot light socket.
I will probably put the rest in the cabin, under the dash and seats, and in the door pockets, all joined together with the controller hooked up to it.
It went to S.A on Monday and back in my hands Today
Recommend for all 32 peeps who have tired looking Steering Wheels, Coz I'm happy to lend my spare while yours is getting recovered.
Total cost = $275 (and a 6pack for me :) )
Sneak Peak on what im currently doing to my engine bay.
Also finally installed my speaker covers!!!! And it was totally worth the almost 1 year wait...
And cleaned both front indicators
Yesterday I played R33 Suspension games again.
I found that the Bump Stops I had put on were way too tall and they were actually taking up some of the weight of the car. (you live and learn) :rolleyes:
So after chopping the stops, the Front Lovell Springs were too low. They looked MAD! but rubbed the guards when cornering.
So I've put the NISMO springs back in the Front and have the Lovells in the rear. Sits even.
(eyebrow height is 335mm both front and back)
Then a Wash. :D
Drove out to Sutton and found the ride not too bad but definitely harsher than Stocker springs.
Stopped for a Pic on the way home.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
