Booked in for inspection tomorrow 3:00pm at Dickson :)
Pretty farken keen!
Got myself a UVP for the day and if it fails then they will give me a weekly UVP to get shit sorted.
The only concern I have is that the black rims might rub on the guards but they passed when they were on the 33
So the swapping of rims was a success, the black rims fit nice on the 34 but they do poke on the front.
Couldn't find the source of the rattle with the suspension, got the back seat with (with robs advice) and everything looked fine.
Removed the spare tyre etc and the noise was still there.
It 100% sounds as if the suspension is loose so I'll have to have a closer look on the weekend, I might grab your help with this Rob if it's okay?
Wish me luck with the inspection today :D
SO I FAILED!
BUT there is a silver lining of this cloud.
Because they found one source of the rattle in my suspension, the front part is missing two bolts.
Also my left blinker has fallen out of the holder.
The guy was really nice and said fix those two things and bring it back tomorrow morning, he will then pass it :)
The bummer though is that I have to now organise another UVP which is bloody expensive at $40 a pop
Umm I don't know how to upload rob but I'll send it to you.
Should be able to steal the bolts off the 33 to pass the inspection and hopefully the blinker isn't too hard.
Hopefully get all that done tonight and go for re-inspection tomorrow before 8:00
Good luck mate, hope it all goes well for you ...
Work on 34 now complete. Happy chappy.
Serviced, new coilovers, new tie rods, rack ends/ball joints, discs machined, PMU pads, brake fluid flushed, Falken 453 tyres, gutter rash removed from rims and a good clean :cool:
and steering wheel recovered. Looks Tits !
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
