sounds like it is permanently earthed
disconnect the small joining plug will obviously turn it off
had any electrical work done recently. Meaning has someone tapped into it to power something else ?
aftermarket alarm, central locking
the 2 wires from the connection to the ring haven't been stripped anywhere and touching metal?
all your doors closed properly? are the sensors in the doors all good?
All the sensors in the doors are working, interior light when its on door and all the doors are close its off, same with the dash board light for door open.
Recently i had the car tuned, after the car was tuned i went to pick it up the indicator started flashing like how if the doors are open it flashes the indicator but started doing when i turn the key on and wont stop so i just disconnected the alarm unit and drove the car home
got told that it started happened after he drove the car with the boot open and also the engine light was coming on as well and was just been told that the car has electrical problem. (everything was working fine when i dropped the car off)
I had the engine light fixed as the tuning was not right and it was detonating so a re-tune fixed that problem by a different tuner
I checked all the alarm wiring and also i put the stock ecu back on just to see if the ecu swapping caused the problem (power fc/stock euc)
Did managed to find that if i remove the black box (smart lock) the keyring light goes off but i can't control the passenger side door for lock and unlock from the driver side and also if i have the alarm connected it just won't stop flashing the indicators
Got a aftermarket alarm system with auto engine start and auto window roll up when the car is locked
Edited by 5hiv
Maybe the guys who put the Auto start/Window roll-up can help out
I use Audiotech in Tuggeranong for the last 12 years and about a dozen cars.
Dave should be able to sort it out
Edited by Sinista32
Hope you get it sorted 5hiv.
I got some woodgrain interior bits about 3 months ago, cut the centre console and put all that in. Just need some black leather to make a shift boot.
Today I finally got around to putting in my electric window and mirror switches. I blew the 25A fuse in hopes that it would work. Changed the facia and it all works.
Yep that ^^^ looks really nice. :thumbsup:
Washed the B17 Pulsar yesterday and fitted the New front weather strips.
They are supposed to be a set of 4 (according to Nissan), they are looking into this as the 2 sets they have gotten for me so far are only the fronts. :/
Washed the N13 Pulsar this morn and put in a cheap set of Red LED Dash lights.
  • Like 1
Haha!!! That's just cool. :laugh:
Drove the B17 Pulsar 1700km return trip to Nambucca and back (over the last week)
Great Car, Didn't miss a beat, A/C on all the way. :thumbsup:
10 hour drive today = Pooped now. :sleep:
Bought and Changed Spark plugs in the SkyHatch and got some coolant for when I change the Thermostat.
Seems Smoother. :yes:
Did a trial fit of some Rims I bought yesterday (Extremely Cheap) for the B17 Pulsar...
post-78856-0-49435500-1420953296_thumb.jpg post-78856-0-42251000-1420953410_thumb.jpg post-78856-0-69839500-1420953539_thumb.jpg <<--- Stockers.
They should be Fully Sick Chrome Starcorp Pro V's.
post-78856-0-86842600-1420953579_thumb.jpg post-78856-0-07027900-1420953816_thumb.jpg
Need the Crappy Black paint removed but will be MUCH Easier than when I did the rims on the 4door as it peels off easy.
Stock is 16x6.5 +40 with 195/60R16 and these are 18x9 +38 with 225/40ZR18. :woot:
Will Need more lows but likely won't get it...
cooz Her Car. :/
oh and F.Y.I... 20 Slim Shiny Alloy wheelnuts with internal Hex and key to suit are $30 from Bob Jane Belco. ;)
Flushed the SkyHatch cooling system and put in New Thermostat and Coolant.
Temp Gauge actually sits near 1/2 now instead of 1/4 and feels a little more zippy??? Less Rich I guess. :D
also put in the New Oil / Air separator crank case breather filter gauze mesh thingo.
HKS air flow less adapters that i bought are on backorder so got a full refund.
but there was a set on Ebay for $200 cheaper second hand! I love it when things go right!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
