I had a great morning, just looking at photos so I can remember what it looks like, in case I get into the wrong car at some time in the far distant future if I am called in to pick it up :)
I'm sure you have posted this, but what are you getting done? Sorry if I had missed the post.
Replaced my rock hard rocker cover gaskets. Gotta love how much info is out on sau
I take it you did the half moons + goo?
I actually just received a new gasket for the RB Thirty.
Only needs one piece. :)
I did indeed. Managed to find you in that thread also. Not surprising.. Always seem to find you in r33 tutorials! :laugh:
So... I got my first flat.
front left tyre shredded on the outside thread and airless. Walked to Servo > then got picked up and went to Robs for help because.. my jack didn't have no jack bar :( (lesson one) and so, Rob was very kind enough to help me change my tyre. I tried to help but I think I was getting in his way. Needless to say, Rob came to the damsel in distress :D So, thank you Rob.
Finally home..
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
