I start a new job on the 24th, and car is set up for nulon nats drags on the 26th. Wakefield eventually though!
Today I got road tyres fitted, installed a EBC and set it up to run 14psi and 19psi as the scramble boost setting.
Also installed a passenger seat.
  • Like 2
good job on the steering previous page
today I put in new door locks, boot lock and will get the new ign barrel put in soon at Johns
decided to cut and use the Nismo key on my gtr32, so it deserved complete set of new locks
  • Like 1
I opened up my bonnet and heard what sounds like a exhaust leak..close the bonnet and drove to the shops lol
That makes two of us haha.. Did pretty much the same thing!
That is so cool!!
I replaced my exhaust manifold gasket because of a leak, got a new turbo gasket thanks to Shiv. Also discovered a manifold stud snapped in the head thanks to previous owners.. Tapped out and all fixed. Just to put it all back together tomorrow! :)
  • Like 2
1.5 way diff installed thank you Canberra Import Spares! Was doing figure 8s out at Harrison playing fields car park breaking in the diff when the cops showed up on reports of a skyline doing donuts.
I had a chat to them for a few minutes and they had a laugh when picked up on what I was doing - no skid marks and tyres in good condition. Told me not to have too much fun and left me to continue. Nice blokes!
  • Like 4
Dropped the rear end to swap back to an s13 subframe. Have to get cv boots replaced and the diff looked at, one of the stubs doesn't lock in.
And of course one of the driveshafts is stuck in the hub so the whole lot has to go to Craig Hall to be fixed.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
