Got 660cc injectors coming from RHD and just got a Hypergear Atr43 G3 Turbo (500hp) and ECU (PFC) is being negotiated. Then POWER TIME ! Hopefully - fingers crossed. I get close to 300kw... but, I won't be holding my breath. I'll be happy with anything between 270-300rwkw.
  • Like 2
